I got a message reading : SPOOLER SUBSYSTEM APPLICATION HAS ENCOUNTERED PROBLEM. Also got: PRINT SPOOLER SERVICE NOT RUNNING. Now, the printer is not installed and can't reinstall program.
Many more thanks sir.
Laser jet 1020printer not inistal on windows vista give faild
Ok, so for this, always had an issue with this one,
so, what i did is started the spooler, the way to do this is you have to go into control panel>>>admin. tools>>> services>>>printer spooler>>> and then you have a blue icon on your left where you have to click on the button that says start the spooler, now i recommend you minimize this window,
next step is that you add the printer through the add a printer wizard in most cases the printer should already have the basic driver installed into the computer. and way to add it to to start the add a wizard, click on add a port make sure the box where it reads plug in play is unchecked, so the only icon you have checked is the local port, next you choose the port that is usb001 from here you choose hp>>> then laserjet 1020, let the printer driver install and finally your done.
printer damage
We have the same problem and have spent approximately $300 to get it resolved. This printer disappears from our system and takes other printers with it. We set another printer as default and are not using this printer at all. This trouble started after we got a new computer! Never had this problem previously.
the printer spooler service is not running rpc server is unavailable
Can find HP JET 1020, but it can not instal
