Whirlpool 25.4 Cu. Ft. Side-by-Side Refrigerator w/Thru-the-Door Ice & Water - Satina Stainless-Look Logo
Posted on Jan 04, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Water dispenser dripping water all the time - Whirlpool 25.4 Cu. Ft. Side-by-Side Refrigerator w/Thru-the-Door Ice & Water - Satina Stainless-Look
Anonymous
Level 2:
  • Expert 217 Answers
  • Posted on Jan 04, 2011
Anonymous
Expert
Level 2:
Answers
217
Questions
0
Helped
70889
Points
750
First be sure the refrigerator is connected to a cold water supply. After connecting the refrigerator to a water source or replacing the water filter, flush the water system. Use a sturdy container to depress and hold the water dispenser lever for 5 seconds, and then release it for 5 seconds. Repeat until water begins to flow. Once water begins to flow, continue depressing and releasing the dispenser lever (5 seconds on, 5 seconds off) until a total of 12 L has been dispensed. This will flush air from the filter and water dispensing system, and prepare the water filter for use. Additional flushing may be required in some households. As air is cleared from the system, water may spurt out of the dispenser.
One or two drops of water immediately after dispensing is normal. It may be necessary to hold the container under the dispenser for 2 to 3 seconds after releasing the dispenser lever.
Hope this will be useful.
Thank you
1helpful
Water dispenser drips sometimes after filling a cup with water. Does not happen every time. If not addressed, the drip continues indefinitely. To stop the drip, I use my index finger to give a good poke...
When water leaks from the dispenser like this it will be caused by a defective water control valve that will not shut properly when off. The leaking water is the same as a leaking faucet. The KSCS25IN uses a=> W10247725-Water Control Valve or HERE
Sea Breeze
Hotpoint HSS25GFT 25.0 Cu. Ft. Side-by-Side Refrigerator with GE SmartWater Filtration, LightTouch Problem: Water continually drips from water dispenser spout
Should be the water valve in the back. Over time the seals break down our debre in water will cause to leak. Sometimes new water filters will also cause small issues but shouldn't last long.
Water dripping out of water dispenser tube
SOUND LIKE YOU HAVE A BAD INTAKE VALVE. IF THE WATER DRIPS ALL THE TIME.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Outside ice despenser is dripping, no ice
water dispenser -Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
ice maker - If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
Water dispenser leaking at the door all the time.
Kitchenaid model ksrs25ilss02 water filter
Are you saying water is dripping out the ice dispenser or the water dispenser, a water filter would have nothing to do with this, it only filters water, it does not pump water nor does it shut it off. If water
is dripping from the ice dispenser, it is because the rubber gasket
is bad on the flap that seals after ice is dispensed. If water is dripping
from the water dispenser, it is the shut off for the water, you can put a glass under it and push for water a few times,on and off and see if this makes it stop, if not you would need to have this replaced. Any questions please post back.
2answers
Whirlpool side-by-side refrigerator - 2 problems
I would suggest that you get a certified person to come out and look at it you very well could have bent the doors in the move.
but... if you want to do it yourself.
click here for a walkthrough
for your drip:
Flush air from the water system the first time it is used and after replacing the filter. Air trapped in the water line or filter may slowly travel through the coiled water reservoir to the dispenser, pushing any water ahead of it. This can cause the dispenser to drip. Water needs to completely fill the lines for all air to be cleared.
  • Use a sturdy container to press and hold the water dispenser bar for 5 seconds, then release it for 5 seconds. Repeat until the water begins to flow. Once the water begins to flow, continue pressing and releasing the dispenser bar (5 seconds on, 5 seconds off) for an additional 2 minutes. Repeat if dripping starts again because air can re-enter from the water supply.
  • As air is cleared from the system, water may spurt from the water dispenser.
  • Make sure the refrigerator is connected to a cold water supply.
5helpful
2answers
Water Dispenser Drips
Had the same problem after replacing over seven water valves and installing a water regulator in the water line to the refrigerator with no help. Had to reduce the water pressure to about 27 pounds the reduce most of the drips. It drips an amount about the size of a quarter and when the water gets the coldest it stops the drip, but there is always a droplet at the end of the water disperser tube.
The problem is with water stored in the refrigerator side of the box. Water come in and does not leak. After the water gets colder it expands and oozes drips from the water dispenser. It is worse with the roll of tubing behind the crisper drawer on the bottom, because there is no room for expansion in the tubing. We replaced the tubing with and older style tank and it helped some, but not completely. The solution is 1. Try to buy a refrigerator with a tank instead of the roll of tubing in the bottom of the refrigerator side. 2. Don't use the water dispenser. 3. Reroute the tubing directly to the water dispenser and bypass going into the refrigerator, the water will not be as cold. 4. Avoid those built by Whirlpool.
2answers
Your house valve may not be totally closed (bad seal or something) letting a small bit of water through. Disconnect the line to the fridge completely (in the back) to be sure. That way even if the fridge solenoid valve is bad AND the house valve is bad you won't get dripping. If you know the valve is good, there are times when the water filter will have air trapped in it letting the water in the line drip out slowly until it's finally empty. Pull any filters you have also.
Top Whirlpool Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
