SOURCE: Insignia portable dvd NS Pdvd8 need battery
Hey redhouse2,
Because Insignia® is a brand primarily carried by Best Buy™ stores, there are two basic ways that you should be able to obtain a replacement battery: by contacting Insignia® technical support, or by ordering a replacement through Best Buy Partsearch.
You may always reach Insignia® by calling their toll-free hotline at (877)-467-4289. If you would prefer a self-service option, simply visit the www.Bestbuy.com website, and follow the link at the bottom of the page that says "Order Parts." Additionally, you may always contact a Partsearch agent by calling our toll-free hotline at 888-Best-Buy (888-237-8289), and requesting to speak with a parts specialist.
Please keep in mind that while some third-party companies may carry compatible batteries for this model, if your DVD player is still under the manufacturer's warranty (or a Best Buy Performance Service Plan) you may wish to seek the replacement part through Insignia® or Best Buy™ first to avoid any unnecessary charges.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
SOURCE: Insignia NS DVD 1A
i have just purchased the ns-dvd1-a player and am having the same problem as above. i have a bunch of DVDs from India and have to return the player to best buy if i can't unlock it. Pls send the unlock code. Note: 9735 not working anymore.
SOURCE: portable dvd player insignia ns-pdvd10 screen problem
Check the screen switch on the right top side where the door closes there is a little circle and the release switch usually gets jammed (this is a common defect) you will need a small thin flat head screwdriver to pry out the switch.
SOURCE: Insignia 27" lcd tv vertical colored lines across screen.
This television, appears to have had a failure in the mainboard. This is the board that controls the video functions and sound functions. The unit should be taken or sent in to a service center for testing and servicing. The service center will have all the correct service information to determine the problem for you. You can call Insignia customer support at this telephone number 1-877-467-4289. You can also got to the customer support website at www.insignia-products.com. Go to the support section and ask them for help on how to get service for your television. I hope this information helps you with your problem.
