Re: The screen has turned very light to the point where...
This sounds like a new battery is needed. To send back into a Polar Authorized service center follow the link here. Yes, you do need to send in to an authorized service center.
It seems that you've done everything that you're supposed to to troubleshoot your tv. At this point, you might schedule an at-home inspection of the tv by Geeksquad by calling 1 (800) 433-5778 . They might have to take the tv for repairs at their base.
I think it is either a fuse or something that burned out that won't let the display show up. Check all solder points on the inside and see if any are broken for sure. Nothing looks bad does it?
Possibly this is why it was at auction...
Let me know if you still can't figure it out and I will see what else I can come up with.
That is equivalent to a "Check Engine" light, meaning that a condition exists which requires attention. Check all fluid levels, and readout codes from the ECU as a starting point for diagnosis.
on the face plate is a button for the counter ,try pushing it several times to see if the dot moves. As long as the channel display is reading the correct channel you should be ok but you want to correct this problem . If you can't correct it contact Galaxy and they will have a tech talk to you.
Turn off printer.
Close readout cover.
Unplug printer. Wait at least 5 minutes.
Plug back in printer
Open readout cover
Turn printer on
This will reset the printer
If this does not work, try turn off printer
Open and close the readout cover slowly couple of times
Turn printer back on
If still does not work, try a different outlet
the voltage could be low.
My Alpine CDA-7842 works fine from a functional point of view but the
display (readout) had stopped working. All the lights on the display
work but the actual readout is blank. At first the readout would
intermittently work now it's completely dead. Any assistance would be
greatly appreciated.
