Changing faders USUALLY involves removing all panel hardware so that circuit board can be removed to get at the fader. It is often a LOT of work with a boit of hazards along the way.
If the control is noisy I want you to try something before replacing the fader. Get a can of CRC226 available at Home Depot in the Electrical department... about $2.70 for a can. Using the included plastic spout tube, squirt a bit into the center of the control where the knob is. Work it back and forth and then put a little more in and test if it is better or fixed.
NEVER use DeOxit or Blue Shower in faders!!!!! It removes the lube that is required in the fader.
