First thing to do is unplug your unit for one hour and then plug it back in to see if the control board will reset itself. If you are still getting the SY EF error codes then you will need to replace the controller board
SY EF is refer to the Evaporator Fan Circuit error; I suggtes check this DATASHEET
Keep us updated.
I dont understand why you cannot open the "datasheet", this is PDF format; try this other link:
-http://manuals.frigidaire.com/prodinfo_p...
-http://www.specsserver.com/CACHE/FRWQJVN...
Keep in mind that the SY EF code means that you have an error with your evaporator fan motor. If you
open the freezer and remove everything out of the freezer, you can
remove the lower back panel inside the freezer. There is a fan behind
this panel and that is your evaporator fan. You will need to replace
this part.
Hope helps.
SOURCE: On the freezer and fridge
There is either something wrong with the fan or the computer. But the
only thing you can do is go through the owners manual if you can't
correct it with that you will have to call for warranty service. If you
go any further then that you will void the warranty.
The short answer is that EF on the Electrolux refrigerator digital
display means "evaporator fan." The long answer is, it doesn't
necessarily mean there is something wrong with your Electrolux refrigerator.
Hope helps.
Hello Suzanne, thank you for your post!
I understand that your Electrolux refrigerator is displaying an error code of "SY EF". An "SY EF" code stands for an evaporator fan circuit failure. This could also be a miscommunication with your refrigerator and I would advise performing a reset on your refrigerator. You can reset it by disconnecting the power plug from the outlet for roughly ten minutes. If that does not help correct your issue you may need to replace your main control board or a wiring harness. For proper disassembly and repair of your refrigerator I would recommend having a professional technician for proper diagnosis and repair. I hope this information is helpful. -Matt
Hi daneilb101 - Typically error code SY EF indicates that the refrigerator has detected an evaporator fan circuit failure. Contact a professional to move forward accurately. The wiring between the main control board and evaporator fan will need to be check and diagnose. Depending on the diagnoses the main control board may need replacing.
i CANNOT OPEN YOUR DATA SHEET BUT MY FRIDGE IS A FRIGIDAIRE PROFESSIONAL I HAVE ONLY HAD IT A YEAR... I THOUGHT THIS MIGHT WANT US TO CHANGE OUT THE FILTERS OR SOMETHING.. I FOUND MY OWNERS MANUAL AND OF COURSE IT DOES NOT TELL ME WHAT THE CODES MEAN.
IS MY FOOD GONNA BE OK UNTIL TOMORROW??? IT IS SO FULL OF FOOD.. BUT I HAVE AN EXTRA FRIDGE OUTSIDE..THANKS
error code sy ef
