Question about GE Security Simon Xt Wireless Control Panel 40 Zones
System says low battery ... how do I open it to replace batteries...very confusing!
    New Friend:
  • 59 Answers
There are two tabs (and possibly a screw) on the top of the Simon XT panel. Remove srew (if installed) and press the two tabs, pulling forward. Front part of panel is hinged and will rock forward. Battery is located behind front half. It is a 6 volt 1.2 Amp Hour lead acid battery.
You must completely downpower the Simon XT (wall plug in and battery) then replace with new battery first, then reconnect wall power. Close the front panel and snap it closedand replace the screw (if it was installed).You will need to set the time on the panel, following the instructions in the users manual.
Posted on Feb 06, 2013
    Filmmaker:
    Uploaded 5 video answers.
    New Friend:
  • 31 Answers
Here is a very easy to follow video tutorial that may help you.
You can get a replacement battery from here
Simon XT GE Security Security Alarm Battery 6V 1 2AH
Posted on Jan 06, 2015
5 Suggested Answers
Anonymous
SOURCE:
Anonymous
  • 36 Answers
SOURCE: the system battery was low and I replaced it. The
The new battery may not be fully charges, need to wait a while.
Also try this enter your code + off, again enter your code + off.
If this dosen't work, remove your battery and power down your system.
Wait about 30 seconds, plig in your battery first and then power up your alarm system. You may have to adjust the time.
Let me know.
Salvo
Posted on Oct 31, 2009
Paul Blessing
  • 188 Answers
SOURCE: system low battery
Disconnect battery and take with you to radio shack or batteries plus for an exact replacement. You may have to enter your code or do some kind of reset after replacing.
Posted on Aug 08, 2009
securetim
  • 31 Answers
SOURCE: Low Battery warning on Simon 3 even when I changed it out
temperature affects batteries. if the batteries on the window sensors have been in use for some time it is probably time to change them. Alarm batteries are only expected to last 3 to 5 years with moderate use. If you have close neighbors or live in an apartment complex then false reads could be a factor.
Posted on Aug 24, 2009
Sean
  • 80 Answers
SOURCE: have a issue that indicted a low battery replaced
disconnect battery put dc meter on wires. should read over 6v if not need new panel. if over 6v put system in sensor test wait 5min then close cover hit status 2 times. if reset great. if not try another battery. repeat sensor test. if resets great if not need new panel. : (
Posted on Mar 21, 2010
New open the remote control no reponse
If it is the original remote conctrol and it won'trespond after you replaced battery, one of the possibilities is that "new" batteries are expired or by confusion you inserted old batteries and disposed of the new one,
May 28, 2015 | Televison & Video
My 2007 Sebring headlights, signals, and wipers stopped working and I was told it was the multifunction switch. In the process of waiting on part I received a jumpoff because I left many hazardous lights...
Sounds like an alternator issue. Could be corroded wires at the battery also. When the voltage gets low, things like these will shut down first. Having the flasher on for five minutes won't drain the battery. Jumping the battery put it above the shut down threshold. Have the charging system checked, before replacing the multifunction switch.
Oct 26, 2014 | Chrysler Sebring Cars & Trucks
Low cpu battery how do i fix it on alarm system
Open the system, unplug the transformer, disconnect one lead of your battery, reconnect the battery first, then the Ac if it says low battery still, then you need a new battery take the one you have go to battery plus get a new one, and reconnect it, it may still say low battery, wait for an hour for the battery to charge, disconnect the AC and battery again, reconnect the battery first then the transformer. It should clear the low battery.That battery is a
6 VDC 1,.9 Ah.
Mar 11, 2013 | GE Security Simon 3 Wireless Home Security...
My bose 321 system remote sometimes works then stops works and works again. I am confused since i have bought new batteries. thank you.
If the fault started ONLY after the batteries were replaced, it is important that in the first place if the battery was leaked and oozed onto to the board.
if so you need to open and clean the board. Also make sure that the contacts of the battery are clean, If not there is fault in the board, it will be good to remove, clean , heat off moisture and reset.
Jul 26, 2011 | Bose 3·2·1 II System
I have a GE Simon XT. I arm the system. When I return several hours later, the front door doesn't beep when I open it. I have to close/open it again to register. Front door is Sensor 1, Group 10. What...
Can I assume it is a wireless contact we are talking about?
1.) Low battery in tansmitter. Does your keypad display a low battery trouble? If so, ensure you put system in test before replacing battery as not to generate a tamper alarm when opening contact.
2.) Relay in transmitter is sticking. Replace wireless contact.
Stewart
May 26, 2010 | GE Security Simon 3 Wireless Home Security...
How do you replace the battery for the vista 15pmt system. I have the low battery light
Open the control box and the 12V 4AH battery is inside. Buty new battery connect black and red wires to black and red terminals on the battery
AlarmProfessor.net
Nov 08, 2009 | GE Security Simon 3 Wireless Home Security...
Westech 5000 battery low and i can't figure out how to fix it
There are 2 posibilities for having a low battery. 1) Your main backup battery for the control panel is low, or 2) You have wireless transmitters in your system that use small batteries and need to be replaced. To replace the control panel's battery look for a large metal box which is the control panel. These panels are normally located either in the basement or a 1st floor closet. Open the panel if you have a key. If you do not have a key take a pry bar and pop the box so it opens. Inside you will find an electronic motherboard with a black & red wire which is plugged into the battery. Grab a hold of the connector at the battery and wiggle/pull until the wire/connector disengages. Do the same for the other wire. Take the battery to a battery warehouse store and have them match it up. Be sure when reconnecting the new battery to plug the black wire/connector into the balck marked side of the battey and red to red. If you have a wireless system you will need to pull apart one of the transmitters & see the type of battery used. Replace all the batteries at the same time. They will last normally 3-5 years. The control panel's battery will last about 5 years.
Aug 25, 2009 | Home Security
Pentax K100D will not power up
First make sure you are using fresh lithium batteries. These cameras indicate low batteries quite early on. Rechargeables even when freshly charged are marginal.
If the problem persists remove the batteries. Set the camera switch to the off position. Set the focus switch to manual. Wait at least a minute. Then replace the batteries and switch on again.
Operating with low batteries can confuse the firmware and it may be stuck in a low-battery loop. If this is the case this should reset the camera by allowing the electronics to power-down completely.
If this does not work you wiil have to contact pentax support.
Dec 31, 2008 | Pentax K100D Digital Camera
Simon 3 "System Low Battery" after 3 years use
I install these panels.  For the low battery message to clear you need to power the system down completely.  To do this you need to unplug the battery and also unplug the transformer plugged into an electrical outlet.  When you power the system back up, you need to first plug in the battery leads.  Then the transformer.
Jun 15, 2008 | GE Security Simon 3 Wireless Home Security...
System Low Battery
Response 1 is correct. If you plugged the transformer into an outlet before connecting the battery the system wont see the battery and give you that error. Should be a simple fix however. Unplug the battery and then the transformer, then reverse the process. Plug in the battery and your Simon should power up, then plug in the transformer. If this doesn't help then you should replace the battery. Did you buy the system from a dealer and have it professionally installed or did you do-it-yourself? If it was professionally installed have your technician come back out to diagnose/replace the battery if needed. Good Luck.
Feb 10, 2008 | GE Security Simon 3 Wireless Home Security...
GE Security Simon Xt Wireless Control Panel 40 Zones Logo
352 people viewed this question
Top GE Home Security Experts
Sean
Bill
Level 1 Expert
Are you a GE Home Security Expert? Answer questions, earn points and help others
