I have an error code E000990-0000 pliiz help me fix this
Posted at Canon Support: When the process unit black locking lever is locked or released, it in turn opens/closes a waste toner shutter mechanism, if this does not occur properly an E990 error code may occur. Check the Cam Lead mechansm (on inside process frame) for any broken gears or a broken cam lead itself, item FC6-9403-000. When the locking Handle for the Process Assembly is turned to the locked position it re-positions a rack that opens the Waste Toner Shutters. When the rack is in the correct position there is a cutout in the rack that unblocks PS12, if the sensor remains blocked an E990 0000 will be generated. Remove the Hopper Drive Assembly and the Hopper Assembly .(With those items removed you will see a white nylon gear plate with 2 locking screws. Loosen the locking screws and position the gear plate so that when the handle is in the locked position, the cutout in the rack unblocks PS 12.
Hi that is kind of difficult even for a trained technician. The sensor that detect the waste toner box is dirty. It's located upside the box in the machine. Good luck
SOURCE: IR2270 copier displaied error code E000020-000
It's concerning the toner level in the dev unitor drum unit. Try entering service mode and selecting 'install' this will stir toner and try to feed toner through. Could be a dirty or faulty toner level sensor. Cuuld also be the drum life over - check drum life in the service mode. Check my other posts to see how to enter service mode
SOURCE: How can I correct error Code E602-0001 on my Canon copier?
You can try to reflash the hard drive or replace the hard drive
SOURCE: canon imagerunner 5000i -error e000121-000 what is the problem?
The controller cooling fan is faulty. Fan Motor 4 ( FM4) Or worst case the DC controller board. Try the fan. Located on the right side rear up close to the top. I believe there is a filter there that could be stopped up. You also could remove the fan motor and drop a couple of drops of oil on the shaft and see if this helps. Good luck! Unplug the copier before you get in there!!
E-121 refers to the Controller cooling Fan (FM4). The fan is dead, or perhaps something is blocking it and preventing rotation. There could also be a short or open in the circuit. Fan vents on the right rear side of the copier. (Facing the front). If the back cover is removed the fan is located (Facing Rear) at the left side of the machine next to the Main Controller Box. Try blowing out the fan it may be plugged with dust Bunnies.
I have an error code E000025-0001 please help me to fix this.
I have an error code E000025-0000 please help me to fix this.
i have an error code E00990-000 please help me sallow
