This is a known issue with HP printers. Do not worry, if you get this message that the scanning software could not be found the please go to the link
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=441125&lc=en&cc=us&dlc=en&submit.y=0&submit.x=0&lang=en&cc=us
Select the Operating System.
From the list select. ...
HP Full Feature Software and Drivers
Then scroll down to the 3rd option......
Click on Download only >> Save the file to the desktop.
Start installation and make sure that the Printer is not connected using the USB cable to the computer.
While installing, you will get the option to connect the printer. Do not connect the printer.
Select the option "I will connect it later". Go next the installation will be complete.
After the installation is complete...leave the CD inside the computer.
Connect the computer and the printer.
It will show you the configuration window.
Wait until you see the "Start using the device" option.
Click on "Start using the device".
You should see the solution center window now.
If it is succesfull. Try scanning using the Solution center.
If it is succesfull, you can now scan using the printer as well.
Try it and let me know if it works and please let me know your issue in detail.
