SOURCE: fisher & paykel smartdrive 508 filling slowly
remove the hoses and check for any kind of clogging or restriction in the line there may also be a problem with your fill valves
SOURCE: Smartdrive 508 fills very slowly, seems to
Hi just read your posting.Is your complete model number GW 508? The fault with your machine is either your inlet hose filters or your water valve filters are blocked or one or both of your water valves are faulty.Turn off the water to your machine and remove the inlet hoses one by one.Check the amount of water coming out of the taps and check and clean the filters,if your inlet hoses have them, at each end of both hoses.Also where the inlet hoses connected to your machine check the filers on the water valves.If all the filters are clean and you still have the problem then the problem will be one or both of the water valves.Please reply on how you got on or for additional assistance.Hope this helps and looking forward to your reply.
