Your Lid Switch Is Broke. You will need a Qualified Service Technician Come Repair it. If you would like to do it yourself you will need the model number so you can order the part from your local parts house and Make sure to unplug the washer FIRST!!! Then all you have to do is pop open the the dash which there should be 2 screws in the front or rear the the washer remove those and slide the dash back once done look to the back left you will see 3 wires going into a quick disconnect plug unplug that and there should be a screw holing the switch to the cabinet just lift the lid and slide you hand back by the switch and remove it and then with the new switch install it the same way until you have replace the dash with the mounting screws. Plug the washer in and put it into spin cycle will turn on and work hope this fixes your problem good luck.
