Sportline 1010 Duo Heart Rate Monitor Watch Logo
Posted on Jan 06, 2011
How do I reset the chronograph? Once I start it I can't find a way to reset it.
ssreenathv
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 01, 2012
ssreenathv
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1657
Points
In heart rate mode, click reset to go to Calorie burned mode. In that mode press and HOLD reset button and this should reset all lap,calorie data. etc
Instruction for accutime xoxo watch
This watch appears to be a battery operated model from the details I can find. Self Winding watches tend to be a LOT more expensive and usually a Big brand name! Assuming the Chronograph is designed to work the two buttons are usually 'Start/Stop', (top button) and 'Reset', (bottom button). Try this.
-Press the top button once. The smaller dials should start moving.
-Press the top button again. The smaller dials should stop moving.
-Press the bottom button once. The dials should reset to zero. There is another function of the Reset button. You can 'Freeze' the chronograph display for things like lap times.
-Start the chronograph, (Top button once).
-Press the Reset button once, (Bottom button). The dials should stop. The chronograph is still running you have simply paused the display.
-Press the Reset button again. The dials should 'Jump' to the current position the timer is at.
-Press the Top button once to stop the chronograph. *Note* Some of the cheaper watches simply have the dials and buttons for the look of it and don't actually work.
Jan 20, 2022 • The Watches
What are the buttons on a invicta watch..model 23696 used for?
This is a chronograph watch. The top button starts the second hand (the chronograph) the bottom button resets the chronograph to zero. You need to first press the top button to start and the press the top button again to stop. then press the bottom button to reset. The hands will not reset if you have not stopped by the top button.
1helpful
How to reset Festina back to zero
Pull out the crown, push the chronograph start button. You will see that the hand moves one second. once it is back to zero push back the crown. Depending on your model you might need to pull out the crown with one click for the chronograph timers and another click for the second hand.
8helpful
Please clarify use of the 3 smaller dials and how the hands to each are set and reset
The small bottom dial is seconds counter and there is no option to set or reset it as it is part of the main gear train - it just counts the seconds. Top right dial is 1/10 seconds counter and runs only when the chronograph function is engaged. One full circle indicates 1 second. Top left dial is 30 minutes counter and runs only when the chronograph function is engaged. One full circle indicates 30 minutes, two circles = 1 hour. The big centre seconds hand is actually Chronograph hand and runs only when the chrono function is engaged. So, the chronograph hand and two top dials works all together when chrono function is engaged. To start chrono: push upper button once. To stop chrono: push upper button again (once). To return all hands to zero: push lower button once. There is another option: if you already stopped chrono by pushing upper button, but want to continue counting without returning hands to zero, push the upper button once more and the counting will start from the point where it stopped. You can repeat this as many as you wish - it will count on and on, till you will stop it and reset to zero. Fine tuning of chrono hands can be made by pulling the crown half way out and while leaving in this position pushing and holding one of the push buttons (which one - depends on movement caliber). Watch has an tachymeter function as well (big inner ring). Learn how to use it by browsing through my Tips and Tricks- it is explained there. Rate me, please.
6helpful
Fossil Chronograph--need to know what the two buttons on the side do
Two push buttons is for chronograph function. When you push the upper button - chronograph starts, second push on same button - stops the chronograph. Push on lower button - chronograph resets to zero. Rate me, plz.
Feb 03, 2010 • Watches
7helpful
3answers
Pressing reset doesn't go to zero. sweep second hand goes to 57 seconds
Pull out the crown and use either a combination or one of the cronograph buttons, this will allow you to adjust the hand positions
How to use the stop watch function
On Casio digital watches you need to cycle through the modes till you get to the chronograph (stop watch). Once there you can use the start stop button to start and stop the chronograph then use the reset button to set back to 00:00:00 when you need to start over.
4helpful
Need to know how to operate Cartier Tank Francaise Chronography W
The top button is for chronograph function and puts the chronograph seconds hand in motion. The bottom button is for resetting chronograph seconds hand to zero.
Do as follows:
1) push the top button once- seconds hand starts moving,
2) push the top button once more- seconds hand stops,
3) push the bottom button once- seconds hand returns to zero.
You can repeat as many times as you like- seconds hand will allways start the countdown from zero.
Depending on what movement your watch has(mechanical or quartz), there can be more variations, but the basics are as described.
If you need more info, supply full info of your watch(make, model, numbers, etc.), please.
Do not forget to rate, please.
59helpful
13answers
Chronograph hand not resetting to 12 o'clock
for my victorinox, the crown out one position and the reset button (lower chronograph button) changes the minute hand and the top (start/stop button) does the 10th's of a second...crown all the way out and top (start/stop button) does 30 second intervals for the minute counter.
Top Sportline Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Sportline Watch Expert? Answer questions, earn points and help others
