Televison & Video Logo
Posted on Jul 10, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Picture-in-picture won't go away
After owning the TV for 5 years and moving cross-country, all of a sudden the picture-in-picture screen shows up in the bottom right section of the TV. We have never used that feature and, in the course of moving, we lost the original remote. We've tried several ways of fixing the problem and nothing seems to work. Any ideas?
RGB in Seattle
  • 1 more comment
  • RGBSeattle Jul 10, 2008
    Mattozan,
    Thank you for your prompt reply. The picture-in-picture box remains on the screen when I am using the DVD player as well as for the TV signal.
    RGB in Seattle
  • RGBSeattle Jul 12, 2008
    After owning the TV for 5 years and moving cross-country, all of a sudden the picture-in-picture screen shows up in the bottom right section of the TV. The screen is on both for TV reception and when we are in DVD mode. We have never used that feature and, in the course of moving, we lost the original remote. We've tried several ways of fixing the problem and nothing seems to work. Any ideas?
    RGB in Seattle
  • RGBSeattle Jul 13, 2008
    Using the menu, and navigating the channel option, I was able to finally get rid of the Picture-in-picture.
Anonymous
Level 3:
Genius:
  • Master 1,011 Answers
  • Posted on Jul 12, 2008
Anonymous
Master
Level 3:
Genius:
Answers
1011
Questions
Helped
562352
Points
2521
Sir,
Your owners manual has very detailed instructions on how to use /undo the PIP feature options; it is very easy to change. Check out....
Thanks
Good luck
Don't forget to rate the solution
Anonymous
Level 3:
  • Master 2,427 Answers
Anonymous
Master
Level 3:
Answers
2427
Questions
0
Helped
872858
Points
6488
There should be a menu button the tv, press it and navigate using the vol+ / - and ch + / - muttons, look in the menu for vide setup and picture in picture, just disable picture in picture mode.,, You can get anoter remote by contacting the manufacture of the tv and asking them for one, they will ship it for you
Anonymous
Level 3:
Master:
  • Master 555 Answers
  • Posted on Jul 10, 2008
Anonymous
Master
Level 3:
Master:
Answers
555
Questions
Helped
174489
Points
1438
Does this happen with TV signal only, or with other inputs as well?
Toshiba no picture
then your optical section has fault.
My hannspree tv screen goes black blank
If the picture shows a picture briefly upon power up then goes off after a few seconds, you have a back light fault. It could have a problem in the 24vdc circuit, failing back light inverter board, or a blown CCFL lamp.
5 year old panasonic viera LCD works great until tonight, screen turned into vertical and horizontal rainbows, can see vague picture behind all the lines like looking through thin black horizontal venetian...
make sure your speaker to your sheron sound isnt to close to it .also if dvd player is the source then move away from tv will demagnatize the tv theres a magnet in them
Hitachi TV: 35TX30B Window in upper left view that won't go away
you using a digital desk top box with it ?
an old school tv
solid state old analog
what you are seeing is called picture in picture
one of those split screen functions of years past
remote may have a function button on /off for that
user manual for one
Hitachi 35TX59K 35TX50B 35TX30B Manuals
No Sound, No Picture
loose connection inside i would check the convergence amp area.
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Pls more info; what do you mean tv on, picture froze? you are watching on tv chanel, do you use cable? I can help you but need more details.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
