I provide this information for those that are qualified and trained to do TV repair work. Entering or making changes in service mode by untrained persons can cause significant and permanent damage to your television. If you are not qualified to service your television, please DO NOT ENTER these service menu codes.
# Using the remote control press:
{MENU} {0} {3} {5} {3} buttons.
{MENU} {0} {3} {5} {7} buttons.
# Then use {VIDEO} or {AUDIO} buttons to enter two different groups of adjustments.
# {VIDEO} and {AUDIO} steps along through the adjustments, and {+} {-} does the adjusting.
# Press the {ENTER} button to save the change.
# Press the {MENU} button twice to exit service menu.
{MENU} {1} {2} {5} {7} buttons.
{MENU} {1} {2} {5} {9} buttons.
{MENU} {1} {3} {7} {0} buttons.
* Then use {VIDEO} or {AUDIO} buttons to enter two different groups of adjustments.
* {VIDEO} and {AUDIO} steps along through the adjustments, and {+} {-} does the adjusting.
* Press the {ENTER} button to save the change.
* Press the {MENU} button twice to exit service menu.
{MENU} {8} {2} {5} {7} buttons.
Mits VZ8 chassis Menus
Option menu, Menu 1270
Service Menu, Menu 1257
Convergence Menu, Menu 1259, 4 Fine,
5 Coarse, 6 Misc.
holding the stop / clear button for 5 seconds or the start button for 5 seconds usually works, see this link http://www.fixya.com/support/t8306273-unlock_digitals_butons
Try holding down the off button for 5 seconds and if this does not work the start button for 5 seconds. Unplug for 5 minutes first. Then try holding the button and then set the clock.
Did your mouse come with any software that lets you change settings, button abilities, etc? Like if you open the software (sometimes you can do this from the "Mouse" menu in Control Panel), there should be a page/tab where you have the choice to set what left click does, what right click does, middle click, middle scroll, etc. And if there's a button 4 and 5, you can usually set them as well. Look through the list and see if you see "Button 4" and "Button 5" options. If so, set each button appropriately. You might also have the option in your software to change the functions of those buttons depending on what program you're working in at the time. Hope I helped. =)
BMW 7-Series - Key Remote Programming Three methods to try: Method 1:
1. Working from within the vehicle and with the doors shut
2. Turn ignition to position 1 and back to off within 5 seconds.
3. Remove the key from ignition and press and hold the unlock button for 15 seconds during this time press the key lock button 3 times within 5 seconds.
4. Release both buttons.
5. Doors will lock and unlock to show correct programming has occurred.
Method 2:
To do this procedure you need to have one working key and one key that needs to be programmed.
1) Get in and close all doors.
2) Turn on the ignition and turn off quickly. (No more than 5 seconds) to start the process. Next action must take place within 30 seconds.
3) Remove the 1st key.
4) Hold the key up near your left shoulder (this is so it is closer to the remote receiver antenna.
5) Hold down the unlock button and press the lock button 3 times. Release the unlock button and the doors lock which confirms the operation.
6) Quickly repeat steps 4 & 5 for key #2 etc.
If it does not work, try doing the keys in opposite order. Key 2 then key 1, vs 1 then 2.
Method 3:
Alternate if you do not have a working remote
1. Turn key to position 1 five times very quickly 2. Remove key 3. Hold unlock button then press lock button 3 times, release unlock button.
4. If you have another key do the same button pressing within 30 seconds 5. Turn on ignition to finalise.
PLEASE NOTE: This programming procedure programs the remote control part of the key. Any transponder chip for the immobiliser (starting of car) will not be programmed and must be done by a specialist.
window.google_render_ad();
I too had the same problem,,and tried it again,,,and it worked for me,,i pushed the button next to the lock light it blinked and i kept holding in the dry button and the lock went off,,,,good luck
