SOURCE: Westinghouse LVM-37w1
I have had this problem since about superbowl time. If I powered the set off, waited 15-20 seconds, and then powered on, it would work again for a while. Repeating this drill a number of times would lead to stable operation. We resorted to a course of turning on some XM music from DirecTV when we weren't watching. I tried a technician knowledgeable on this set, and it would have cost $500-800 to repair the set. We learned from different forums that the likely culprit was either the power supply board or the LCD controller. We also picked up the rumor that Westinghouse had quit making replacement part. It would seem that the management of this organization has a death wish. TO THE CHASE: shopjimmy.com is now selling parts from canibalized sets. They have a non-DOA warranty and a good return policy. A power supply from "Jimmy" solved my problem. I have one important hint: To remove the back, take out the obvious screws and the base. Then remove the ~5/8" rods that protrude from the bottom. There is a screw up inside each rod.
SOURCE: Westinghouse lcd tv ltv-27w2 no picture or sound
power supply first one...second one input hdmi pcb defective..
SOURCE: westinghouse tv ltv46w1hd sound no picture
Need part for westinghouse LTV-46W1 no Picture
need to get Back light Inverter where to buy it.
SOURCE: I have a Westinghouse TV , when turned on the
I just fixed the same model and with your symptom. What it appears to be is the main module is locking up just after the Logo goes away. All you can do is unplug and try again and all you will get is the logo for 5 seconds and then black screen, no sound and led stays lit. Cannot turn off or on. The power supply is actually working fine, it's the main module that has died. This module is no longer available, the part number was W470PROLX68. What i did to restore operation on this unit was to insert 3 volts into the plug going to the master inverter board and then plugged the tv AC cord in. The set showed the logo and then it started working. I removed the 3 volts and it has worked every time since then.
Here is what you should try to do: First take two AA batteries and solder them in series and attach two short wires so you can use it as a power source. Now you have a 3 volts power supply. Next Remove the stand first before removing the back cover. Looking at the back of the unit you will see the power supply and the main circuit boards in the middle (under metal shields) and two boards on each side. These are partially covered with a metal shield, the one on the left side is the master inverter, the one on the right is the slave inv. They both have a plug and wires going to them from the power supply, but the one to the master will have two extra wires. I believe the colors are purple and blue, and they are separated with an empty hole (unused part of the plug). The wire on the end is where you will hook up the positive lead of your battery pack. The negative lead simply goes to the metal shield. With these hooked up plug the tv into the ac and give it a couple seconds and hopfully you will see the tv come on. If it does then disconnect the battery pack and try it without it. good luck.
