First the button clear position
anfter press hold reset 20sec
it will reset
after turn off PABX
move the button to open position
and strat the PABX
Please let me know this is helpful
Testimonial: "Gulazarh4 is very active and willing to help out.. he is a guy who has patience and the "know how" to help out newbies in this field. once again thx"
the same; it doesnt change. let me make sure. this is what i did.
the pbx was in an on state. i changed the nor-> clear. then pressed the rest button (when reset button was pressed the led goes off) after approx 20 secs i released the reset button. and the led came up blinking. i switched off the pbx after led became stable. then moved the clr-> nor and then switched on the pbx.
but the macine has not reset.
thanks
1.Switch2 move CLR position
now green led blinking normally
2.press RESET button 20sec
after telese resset button led is blinking fastly
3. this time move the switch2 NORMAL position
now the led is stable.. PABX is reseted
Please letme know is this helpfull or not
yeah, the last solution worked. thanks buddy you rock;
Please take action if is satsfied on your fixya window
Hello, will this reset all PBX settings to default as well or only password?
this will be reset all PABX settings.... all data will be lose
factory settings
plz let me know this helpful
Hi Gulzar,
I'm tryiing to reset a PBX KX TES 824 LA following step that you list here, but don't reach to reset the PBX. Another tip to achieve the reset?
Thanks in adevance!
turn the power off , then slide the clr/open switch to clear, turn the power back on then ppress reset button for two secs wait for about 10 secs then slide back the switch open (0normal). Press reset again and try out your program. It should have reverted back to default pasword
i have a PBX KX-TES824, I want to remove the password without loosing any stored configuration....
