Question about Elgin Watches
I'm looking to get a new crystal replaced in my mother-in-law's Elgin watch. It has a bracelet style band with a small retanglular shaped/curved crystal. My father-in-law bought it for her Christmas one year and it has more sentimental value than face value. I need good advice/recommendations on what to do/where to send it for repairs. I've looked here on the web but can't find where I can send a newer Elgin watch in for repairs. Please help because my mother-in-law will be bothering me about it.
    President:
  • 2,501 Answers
Their watch site is not too helpful but there is a contact link (go to http://www.elginwatches.net/elgin-watches-contact-us.htm ) and they should be able to help you.
Posted on Jan 06, 2011
Anonymous
SOURCE:
What is the value of my Elgin watch serial #ELT304ST
I had s/n ELT506RM which was not nearly as beautiful as your model. I sold mine for $12,500 so you should value yours higher.
May 15, 2014 | Watches
Where are the model number and serial number on a rolex
Thank you for contacting FixYa.
  • Look at the side of your watchcase. On the watchcase lugs, located where the watch bracelet is attached, you may see one small hole on each lug where the spring bar is located. This means your Rolex has the traditional pierced lug style. If your Rolex does not have the pierced lug style, turn the watch over, and look for the long spring bar in the space where the bracelet meets the watchcase. The spring bar attaches the bracelet to the watchcase. The directions for removing the spring bar on both watch styles is slightly different.
  • 2
    Use your thumb to press down on the link where the band meets the watchcase if your Rolex has the pierced lug style.. If your Rolex does not have pierced lugs, turn the Rolex over, and press down on the link where the band meets the case. Either way, you are applying gentle pressure to the same link, just different sides of it. Remember, you are only removing the side of the band at the bottom of the watch, so press on the link below the 6. Maintain gentle pressure on the link while performing the next step.
  • 3
    Insert the tip of your spring bar tool into the lug holes, and push the spring bar inward. When done correctly, you will feel the spring bar fall into the case, rather than pop back out. Repeat this step on the other side of the spring bar.
    For a nonpierced lug watch, place the tip of your spring bar tool on one edge of the spring bar, and push inward, until the spring bar falls into the case. Repeat this step on the other side of the spring bar.
  • 4
    Pull the band gently away from the watchcase. It should remove easily. You can now see the serial number on the watchcase.
  • The reference or model number of a Rolex is located between the lugs at the 12' position. It is also listed on the certificates Rolex issues.
    Hope this helps. Jewel
    Oct 07, 2010 | Rolex Oyster Perpetual Submariner Date...
    I have a Relic watch that is probably 20 or 30 years old. It still runs well, but the bracelet band is broken. I live in Monroeville, PA. Where can I get the band replaced?
    mcdevito75 Here, You can go to Ebay or simply look for a small watch repair shop in your area for a new Bracelet for your Reic watch.
    Sep 24, 2010 | Relic Watches
    Unclear as to how you adjust the rubber band strap
    1. Remove the deployant clasp from the watchband. The clasp is attached using spring bars on each end of the clasp. The method of spring bar removal varies but is usually performed by pushing a small pointed tool (one end of a spring bar tool) into a hole at the end of the clasp. While depressing the spring rod, pull the buckle away from the bracelet to detach. Repeat this for both sides of the buckle.
    2. Step 2 Measure the watchband to determine proper sizing. Use the scissors to cut along the inner grooves to remove needed sections (each section of the rubber will contain a new set of holes for the bracelet spring bars). Cut carefully and conservatively, as this step cannot be undone.
    3. Step 3 Reattach the buckle to the band after resizing. Reverse Step 1, pushing the spring bar in while sliding the buckle back into place.
    jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
    Aug 16, 2010 | Tissot T Race Case Stainlesssteel carbon...
    How do you adjust the steel watch band of a Citizen Sky Hawk A-T? JY0000-53E
      Making the Band Shorter
    1. Step 1 Stand the bracelet up on its side. Look for arrows on the inside of the bracelet.
    2. Step 2 Insert a small pointed tool from your hobby or watch set into the tiny holes on the edge of the bracelet. Insert the tool in the hole at the base of the arrow. You will see two holes on the edge of the band. Both pins need to be removed.
    3. Step 3 Push the pin out with force in the direction the arrow is pointing. Repeat this process on the second pin. When the pins are removed the link will be loose.
    4. Step 4 Remove the link from its neighbor and replace one pin to secure the bracelet.
    5. Making the Band Longer
    6. Step 1 Remove the link closest to the clasp by putting a small, pointed tool into the tiny hole on the edge of the watch band.
    7. Step 2 Push the pin out so the link is detached from the clasp.
    8. Step 3 Put a new link next to the detached link and line them up so a new pin can go through their holes and attach them together. You may need to snap them together depending on the type of Citizen bracelet you have.
    9. Step 4 Place the pin into the hole on the edge of the band and push the pin through the band with your sharp tool to attach the two links.
    10. Step 5 Repeat this process if you need to attach more than one link.
    Aug 14, 2010 | Citizen Watches
    Puma PU100041004 Watch Black Leather bracelet replacement/repair
    mcdevito75 here, BEST BET, look for a small watch repair shop in your area for a replacement band.
    Jul 10, 2010 | Puma PL1050
    Need a new watch band
    mcdevito75 here, Ebay is a great place for your watch band, but you should know the watch band size in MM, or you can look for a small watch repair shop in your area.
    Jun 17, 2010 | Locman Titanio Tonneau LOC/484/CRBRD/BK...
    Chaika watch
    You probably visited jewellers, not the proper watch repair shop. Even if the crystal is curved, there are suppliers. If the crystal is not round, then this should be hand made.
    Mar 27, 2010 | Chaika Appointment (amazon-stone)' Ladies...
    Stainless steel band won't snap into my watch
    Stainless steel bracelet ends (so called wings) must be curved flush to the watch case.
    Another way is to use curved spring lugs (pins).
    Dec 12, 2008 | Philip Stein Teslar Large Gunmetal Watch
    Watches Logo
    909 people viewed this question
    Top Elgin Watches Experts
    jdthefixer
    Janelle Schoonover
    Janelle Schoonover
    Ruth summersides
    Are you an Elgin Watch Expert? Answer questions, earn points and help others
