The LD error code on these machines is like having a business consultant come out and look at your company. What he or she will tell you is technically correct and absolutely useless as far as fixing the problem.
The error normally occurs when you have an obstruction in the drain line. It sounds like you have checked this out, but I would recommend you remove and clear the drain pump and you might as well do the same for the recirculating pump at the same time. Put things back together and see if this does not solve the problem.
If it does not you could try replacing the drain pump, but it is an expensive part and you will not be certain this will solve the problem, as the problem could be in the wiring or the main control board.
There is also a recall on these machines. To see if your machine qualifies,
Call 1-800-659-7026
