Forgot the combination to the lock. Is there a way to retrieve the combination or return it to its factory default combination 1, 2, 3, 4, 5
The instructions below are copied from the programming instructions (page 11):
ERASE ALL PROGRAMMING
(The "out of box" factory default will be restored)
1. At the back of the lock, remove the screw at the bottom of
the lock housing and remove the cover.
2. Take out the battery pack and remove battery power by disconnecting
the battery pack.
3. Plug in the (provided) male shunt connector into the yellow
wire female connector.
4. With shunt connector connected, re-connect the battery
pack. The lock will immediately sound 3 short beeps (if
these 3 beeps are not heard, then restart at step 2).
5. The lock will then sound more slow beeps, 1 beep for every
second it takes to clear the memory.
6. After a few more seconds, the LED will slowly alternate between
flashing red and green--disconnect the yellow wire
shunt connector.
7. The LED will continue to slowly flash green and red for 25
seconds. To enroll Function Cards, proceed immediately
as follows:
• With the lock LED slowly alternating between flashing
red and green, present the Function Card #1
to the lock. The lock will sound 5 slow beeps.
• The lock LED will flash green rapidly. The lock is
ready to enroll the Function Cards.
• Re-present Function Card #1 to the lock. The
lock LED will flash green then red, with two beeps
(indicating the card was enrolled successfully).
• Present Function Card #2 to the lock. Again, the
lock LED will flash green then red, with two beeps.
• Continue to present, in order, Function Cards 3-
9. Each time a new Function Card is presented, the
After the 9th Function card is presented, the lock LED will flash
green twice, sound two beeps, and will then remain silent,
ready for use. Note: If the lock continues to beep after presenting
the 9th Function Card, check to verify that the yellow
wire shunt is disconnected.
Note: If you only wish to use the first 3 Function Cards, simply
allow the lock to "time out" after 30 seconds.
Here is the link to the complete instructions, in PDF form. You will need Adobe Acrobat or equivalent to view them:
http://napcosecurity.com/download/PL3000_WI1280A.04_PROG.pdf
Good luck-and please provide feedback if this helps!
