The problem is simple and easy to fix. Your washer has a tubing which runs from the base of the tub to the water pressure switch. It might have vibrated loose from the switch, or their can be some sediment in the tub. Blow out the tubing and reattach it securely to the switch and pump out the water in the tub. Then try it again. I wrote an article about this:
Help my washer is overflowing !!!
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Here is your Service Manual and more
Thanks for using fixYa
THE Mobilian.You Rock!!!!!!I did your fix on the pressure tub(it was disconnected )and the washer NOW Works Great.I had water leakin like a cow pissin' on a flat Rock,and kept fillin'. Your fix got me up and going and scored some points with the wife Too!!!!! Thanks Man,if you were in my town I'd be buyin you a Beer right about now.Thanks again!!!!!
Jim G.
