You don't program the TV to the remote, you program the remote to the TV
Find the Vizio codes on the paperwork that comes with the remote. There will probably be several codes. You need to try each one. Before programming turn the TV on manually. After put in each code try turning the TV off with the remote. Then try to turn back on and try volume up If OK everything else should work. Occasionally 2 different codes will turn off the TV in the test above. Use the one that allows the most functions to work
FINALLY not every "Blackweb" remote will control every TV You may need to get another one that specifically says it can control Vizio.
FINALLY not every universal remote will control every TV You may need to get another one that specifically says it can control Vizio.
1) retight the springs contacts batteries with pliers for a better contacts 2) open the r.control and clean the keypads very well from dirty, oxide, and bad contacts, with contacts cleaner. 3) otherwise you must go to the repair shop TV. God bless you
Here you go. This will work with most all universal remote controls. If you don't have the code do the following: Automatic Programming With automatic programming, the remote control tests all the codes available on the Code List and assigns the correct code for the selected device. Although this method can be more time-consuming, it eliminates the need to look up codes and enter them manually.
1. Turn off the device with which you want to use the remote control.
2. Press and hold the corresponding button on the remote control (TV, VCR, SAT, DVD, CAB or AUD) until POWER INDICATOR illuminates. It should take a couple of seconds for the light to remain solid. The remote control is in programming mode.
3. Press and release power button. The POWER INDICATOR flashes once and stays on indicating the unit is in Power Scan mode.
4. Press CHANNEL up or CHANNEL down repeatedly until the device turns on.
5. When the device turns on, press OK to store the code.
Note: • To exit without storing the code, press BACK. • T he unit will search for the next code or the previous code if you press CHANNEL up or CHANNEL down after the device turns on. (go slow you need to press OK when the TV turns on) if you mess up turn TV off and start over. 6. Press any other button. If the device responds, the remote control has been programmed. If the device does not respond, repeat steps 2-5.
Fill free to ask me questions about anything..........................
ok try this first, remove the batteries from the remote and yes make sure you replace them with brand new ones, but before you do that unplug the tv from it's power source and let it sit for a couple minutes at least 3, then plug it back in , put the batteries back in the remote and see if you have everything back, if not I would return everything since you said you had just purchased this set, or contact the makers web site and see if they will provide a new remote since taking the tv back is a real pain.
There's a setting in the menu. I think it's called "smart audio". It's supposed to adjust the volume automatically for commercials. But I don't think it works that well. Give that a try.
