I would suggest using dedicated input button on remote, not the menu on the tv. If you can skip setup screen that would be best. I have just looked at the manual for that tv, it tells you all you need to know, depending upon which input you used for your box. As I stated use the direct input button on the remote if you have it.
SOURCE: HDTV Sharp- Input select to watch Cable tv
On the sharp remote you will find an input button. You depress the input button and a menu will appear and highlight the input you are presently on. Hit the input button again to select the next input. If you wait to long to depress the input button it will not work and you have to begin again. This unit will only hightlight inputs have a component hooked to that input.
SOURCE: how do I get my Sharp Aquos LC-32D43U to work as
Not sure why u need to go to menu. If you want to connect lapotop to TV attach the cable turn on laptop and monitor and hit FN F5 the laptop screen will then be diusplayed on monitor Fn F9 turns it off
please4rate my help++++Thanks for using FIXYA
SOURCE: connected the cables to the
okay lets do a cable check... cable from wall /outside connected to cable box in, from the cable box out to (please note any DVD recorder or VCR should be connected here if you have and then on to TV) TV in ..... TV on , turn to channel 3 (this should be the only ch locked on the TV no scan is needed) you are using coaxial cables... if this was/is a hi def connection (your set should be on component)
SOURCE: can't get rid of "Please Run Channel Auto Scan" stays on tv screen
for some reason it is not seeing you cable signal. you will need to make sure you have it set up for cable and not air. check your input options, like tv/av/hdmi/ ect hope this helps
