SOURCE: LG Front Loan washing machine
If your LG is similar to mine, there could be water in a hose that is located behind the small door on the bottom front of the washer. Open the door and drain the hose. Be sure to have a bowl or pan to let the water run into. Once the water is drained hopefully the washer door will open. When i brought my washer this was one of the selling features the sales person told me about.( The door and hose are accessible to the consumer to prevent them from having to call for a repair) Hopefully this will be your only problem. I bought an LG washer on June 28, 2008. It is now August 21st and my machine is still broken. It broke the FIRST time I ever used it (July 13th) and it still has not been repaired. (Per the repair person it is a water sensor problem which has been "ordered") I wish I had purchased another kenmore instead. I had my kenmore 16 years and never ONCE has a problem with it. I simply wanted to update my laundry room. WHAT A MISTAKE for me to purchase LG!!!!
SOURCE: LG front load washing machine - need to replace drain hose
It's jusy one clip go in from the bottom
SOURCE: Clean LG WF-T652a Top Loader Washing Machine
I have this problem too and I solved it easily !!!!
I hypothesised that something was blocked by dried up lint/silt. So I filled the machine with very hot water and also poured hot water down the lint filter outlets. I left it for 5 minutes and then started a wash cycle - and the water now comes out of the lint filter ducts. ! :-)
SOURCE: The filter bag on centrex
SOURCE: I have a 5.5kg Top
Hi - are these particles kinda ash grey black in colour? if they are then the bellows have sprung a leak.. unfortunartely the only way is to replace the inner stainless drum.
Inspect the top of the bowl for any signs of structural damage along the grey plastic housing as it contains very fine sand used to counter balance the inner bowl.. on rare ocassions these leaks and give you the particle effect similar to what you've described..
