Question about Hoover Nextra HNL 3166 Z Front Load Washer
Hi I have a Hoover optima 1400 nextra 8 front loading washer and the delay button keeps flashing, water wont drain and spin so load never ends - its holding my washing hostage! Some one suggested pressing the delay button 6 times fast or turning off power for an hour and retrying but this hasnt worked. Any suggestions.
  • Hoover Master
  • 757 Answers
FLASHING what ~ please?
Posted on Dec 25, 2017
6ya staff
SOURCE:
Anonymous
  • 108 Answers
SOURCE: No draining on washing machine
I am not an expert on hoover - mainly hotpoint...but..
To empty your machine of water reset the programmer to Final spin. the machine should empty normally.
On hotpoint if you have a fast flashing light its most likely to be 1 of 2 things.
1. The belt from the motor has broken. (price for belt is less than 20 pounds.)
2. The brushes in the motor have worn down too much to make the drum turn. Look underneath the washing machine to see if black power (Carbon) is deposited under the motor.
(Price for set of brushes is less than 20 pounds)
Labour should be no more than half an hour by anyone decent.
Regards
Posted on Feb 22, 2008
Robert Hirst
  • 833 Answers
SOURCE: washing cycle seems to "stick" and time delay button flashes
If this is a mechanical timer, it is probably in need of replacement.  Be sure that there is no impediment to movement of the knob.  You might get lucky by removing the knob and squirting in a small amount of WD-40 or similar solvent.
Posted on Dec 12, 2008
Anonymous
  • 3 Answers
SOURCE: How do you remove the filter for a Hoover washing
I included a link on Youtube to my Nextra where I show how I clean the filter (watch it from 08:55 onwords). Just remove the kick strip and unscrew (philips screwdriver needed) the little screw on the filter itself, then turn it anti-clockwise but while you're doing this make sure you insert the kick strip underneath to gather the residual water. Repeat this operation 3 o 4 times until the sump is totally empty, make sure you don't let the kick strip fill up too much otherwise you'll be spilling water all over the place, so just turn the filter clockwise everytime you want to stop the trickle of water. It's not too complicated and it won't be too messy if you follow these instructions carefully. Good luck ;-)
Posted on Nov 05, 2009
Anonymous
  • 3 Answers
SOURCE: Hoover Nextra 6 1400 6+4kg - the tumble dryer
under top cover there are 2 thermal cut outs to reset.situated centre front
Posted on May 26, 2010
lez1967
  • 5 Answers
SOURCE: Have a hoover optima 1400 only a few months old. i
check u have not got any blockages in the pipe that leads 2 underneath ur sink
Posted on Jul 07, 2010
Wont drain
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Feb 14, 2011 | Hoover Nextra HNF 3157 Front Load Washer
Hoover HNL 662. 'Delay start' light comes on and stops machine
my hoover nextra hnl 662 want wash or spin and the delay staart light flashes 5 times please help iv only had the machine a year and had nothing but trouble with it wouldnt recomend one of these washing machines to anyone jakki
Feb 16, 2010 | Hoover Nextra HNL 3166 Z Front Load Washer
Washer keeps stopping and is still full of water and the delay start button is flashing
Drain pump is either blocked or failed. Check the pump filter which should be at the front right of t he bottom of the machine. If this is clear, you may have to remove the pump to get debris out of the pump housing. Ly the drain hose on the ground to drain the machine first and unplug before going at it.
Dec 08, 2009 | Hoover Nextra HNWL 3166 Front Load Washer...
Machine not draining
Can you hear the pump running just before the spin cycle, if so then I suspect a blockage in the filter or pump hose, If not and machine is quiet then it could be a faulty water pump or PCB board and you would have to call a technician.
Apr 13, 2009 | Hoover Nextra HNF 2137 Front Load Washer
Water not draing away and machine is not spinning
Empty your machine manually by lowering the drain hose into a bowl or bucket. Then remove the kick plate and check the filter for blockages.Before replacing try the machine on drain to see if the pump is running, if problem persists there may be a blockage in the pipe from the drum to the pump.
Nov 15, 2008 | Hoover Nextra HNWL 3136 Front Load Washer...
Program don't start, flashing ligths (start and "delay start" button) for 5 times.
What does the error code mean do you have any idea Is it mentioned in the Hand book. At any rate logic suggests a watewr supply problem that the first thing a washing machine needs - water. So a tap not turned on a Kinked hose An inlet valve solenoid failure- Three things for you to check
Jul 31, 2007 | Hoover Nextra HNWL 3136 Front Load Washer...
Hoover Nextra HNL 3166 Z Front Load Washer Logo
227 people viewed this question
Top Hoover Washing Machines Experts
peter gittos
peter gittos
Gerry Harvey
Gerry Harvey
Poppa Maddo
Poppa Maddo
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
