Bulova Watch Logo
Posted on Jan 08, 2011
My day on my cerruti watch does not go back only goes in front
I need to replace the cracked Glass of Cerruti model ref.69601
A good watch repair shop can do this work. Not cheap, but if you like the watch, thats the way to go.
How to switch 12 hour from 24 hour in cerruti 1881 digital watch
Hold down the C for about 2 seconds (set Hold) will appear and the time offset valve will flash on the display. Press B twice to display the screen for selecting 12-hour or 24-hour timekeeping. Press D to select (12-hour) timekeeping.
Note: The PM indicator appears between noon and 11:59 PM. After all the settings are the way you want Press C to exit the setting screen.
My cerruti watch always stop at 11:30
It sounds as if the watch has taken a knock, and the hands are no longer properly aligned (that is, no longer at right angles to the stem, so that they rise up and down with respect to the watch face as they rotate, and typically try to 'cross' at a particular time of day).
If this is the case you might be able to see it if you first pull out the winder to the time adjustment position, then look closely across the watch face as you rotate the winder.
If I'm right, it's not a big job to correct it, but not one for the enthusiastic amateur. If you value your watch then take it to a reputable watch repairer.
I hope this helps.
I am looking for a leather watch strap for cerruti 1881 grande classico uomo. Where can I find such a watch strap?
I am looking for a leather strap for Movado Vizio 1881. Where can I get such strap?
4helpful
How to adjust day?
If the day is in a window next to the date, pull the crown out one position to the same position used for the date correction. Often turning one way changes the date, turning the other direction changes the day. If your day is on a small dial on the watch dial then pull the crown out two clicks and go around 24 hours at a time and you will see the day advance.
I have lost the warranty card n need to get my cerruti watch fixed..some of the crystals have fallen out and the watch is nt workin anymore..its 2 yrs since i bought it ...am in india bangalore
Try going back to the supplier to see if they can supply you with a proof of purchase.
I would expect suppliers of this quality of watch to keep a record of their sales.
Good luck.
2helpful
4answers
Cerruti watch strap cannot be changed in any watch specialists in middlesbrough and i am just wondering where i will be able to get it done
You probably will have to send it away to get sorted (make sure you send it insured and very well protected).
You should contact cerruti to see who the repair shop is in the UK, (not sure they have one.)
Failing that you may be able to buy a replacement strap of ebay and have a general watch shop change strap for you.
Or find a jewellers that sell straps, they should have one that fits.
Please dont forget to vote if you liked my answer
thanks
2helpful
I have a Cerruti watch 61191, can any body tell me how to set the date dial on it???
You pull the knob for time-adjustment but only pull it half-way. Pulling it all the way lets you set the time, and half-way through lets you set the date.
Top Bulova Watches Experts
ZJ Limited
ZJ Limited
NOEL
NOEL
Are you a Bulova Watch Expert? Answer questions, earn points and help others
