Yes you can - but not with a USB cable. USB is only for data (file) transfer.
What you are attempting to do is use your TV as a PC monitor, therefore it needs to be connected to your TV using a PC monitor cable (15-pin D-SUB/VGA). You will also need a separate audio cable from your PC to your TV if you want to use the TV speakers for audio. If you are using a receiver or amplifier with external speakers, you can connect the audio out from the PC directly to the amplifier/receiver.
It is also possible to connect the PC to the TV with an HDMI cable if your PC has an HDMI out port. However, some TVs wont accept an HDMI signal from a PC and this method of connection can cause other issues, so I would recommend using the PC monitor cable method.
Please let me know if you need further assistance.
Regards,
BElectric
Buy a HDTV that has HDCP
capabilities. Most will have this in at least one HDMI input but be
sure to verify this before buying the TV.
Notice that "in
at least one port." Not every HDMI port on the TV will be HDCP
compliant so be sure to read your TV user manual if you plan on
connecting a HDMI cable to your TV.
ok
