Have had it under water and all was working fine. the camera lens cover will not close, i've recharged the battery but absolutely nothing on it will work. on vacation without manual and no camera....
Well I know what the review says about underwater to five meters http://www.ephotozine.com/article/Olympus-Mju-725SW
but I would take it with a pinch of salt frankly. You could get onto Olympus and tell them you know- 'You said I could take it under water - now it wont work' - They may replace it
Lens cover not close, This will happens due to two reasons.
1) Either your camera battery got died or need to be recharged or replace.
or
2) Your camera is malfunctioning and need service (repair).
To resolve the problem. first check battery on your camera, If battery indicator shows battery low, than you need to charge it or you need to replace your battery.
Rating the solution is highly appricaited...Good Luck.
Hi, The problem is of zoom lens motor which operates lens cover along with zoom, and it needs replacement with new part, and camera will start working fine again. Thanks for using fixya
The battery was tested and showed to be fine. The camera just malfunctioned during the shutdown. The used battery was put into a new camera and it's been fine.
My camera stopped working during a wedding. The lens is stuch out, it will power on, but right after turning on, it beeps 3 times, then turns off.
Hope we find a solution!
The following blog outlines some simple repair options for a lens error. But please first try the listed Fix #2. I heard that fix particularly works well for a camera who's battery had run down with the lens open. Please post back here with a follow up comment if any of the fixes work:
hello,
as you said lens cover does not shut it means camera is in working
mode so naturally it drains the batteries. Actually the problem is in the lens assy. so go to samsung shop.
good luck...
