Question about Proform 495pi Treadmill Frontdrive Roller 219035
Belt is slipping and I need to know what maintenance I should be doing on this model as I have no manual for it.
  • 297 Answers
Hello, There is no maintenace required. Some people like to oil the walk belt, The manual say to do this annually. To do this you loosen the walk belt and applty some synthetic oil to the walk board under the walk belt, then tighten the belt and the belt will distribute the oil where it needs to go. As far as the walk belt, just make sure that is stays in the center of the walk board. Now your front roller and drive belt. The roller does not get serviced, it has perminently sealed bearings. The drive belt usually lasts for many years, if you remove the motor hood and see alot of black dust, it will be the belt. At that point you need to see why it is comming apart/rubbing. After you determine that, you would want to replace it.
The slipping you are describing could be the drive belt slipping on the front roller or the drive pully on the front roller. To find out you need to remove the motor hood nad get on it and look. What you will be watching is the drive belt as it goes from the drive motor to the drive pully. When you try to stop the walk belt you will either stop the drive belt or stop the walk belt. If you stop both, the drive belt is at fault, if the motor keeps turning. If you stop the motor, the motor or the controller is bad. If you stop the walkbelt and not the drivebelt you have a bad drive pully on the front roller, and need to replace the front roller. When you do this you need to remove the drive belt, this is a ggod time to replace it.
Hope this helps, rate my solution if it helped you. Thanks, Matt
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
Posted on Jan 10, 2011
I have 115,000 miles on my car and it runs great. Do I need to worry about the timing chain/belt replacement?
If it has a timing belt, the belt should have been replace at around 80,000 miles. So you are running on borrowed time.
If it has a chain, the chain and gears are designed to last the life of the engine, or around 200,000 miles.
Oct 21, 2015 | Cars & Trucks
My dryer was working completely fine but the last load I did, it smelled like rubber was burning. Is it the belt? If so, how do I fix it? If not, what could be wrong and still, how do I fix it?
It would be helpful if you post the make and model number. With that in mind though you should know that dryers are not maintenance free. They need to be cleaned out at least once a year. Many home fires are caused from the lack of maintenance. What you need to do is look at the front and see if there is a panel that comes off. This will be the whole front of the drier under the door. Some models don't have it. If yours does, look for screws on the area below the bottom edge. Remove those and the panel comes off and you can see the underside of the drum and the heating element. Make sure you clean this area out. The dryer pulls air in here and lint and dust build up and can cause the heating element to catch on fire. If your model does not have the removable front panel then the opening is in the back or the whole top lifts off. Same thing applies with cleaning. And then you can look at the belt that goes around the drum and over an idler pulley and then to the motor. IT may be the belt is broken or slipped off.
Sep 28, 2015 | Dryers
Squeaking
I have worked on some dryers of my own. The first thing I do is either purchase or go to the library and look at the maintenance/repair manual. These manuals have trouble shooting sections that are very helpful. Also, google it. I found several sites that appear to be very helpful. Squeaking is usually dry bearings some located in the rear of the unit, worn belt, worn carrier bearings or belts.
Nov 04, 2013 | Zanussi ZDC37100W Electric Dryer
I have a life fitness t5 and live in the middle of nowhere in new Mexico. I run at 6.5 mph for 40 minutes around 5 times a week. I have used it for approx 1 year. It is impossible to get reliable...
Dear Sir:
I will indicate some Tips for maintenance:
Any equipment is difficult to survie without a properly maintenance.
But you can do something very simple.
Cleaning Dirt and debris is a major cause of premature belt and deck wear. Clean between the belt and the deck once per week. Also clean the small exposed areas of the deck on each side of the belt. Dirt tends to accumulate in these areas. Wipe down the entire treadmill once per week. The outside surface of the belt can be cleaned with a damp sponge or cloth. Vacuum or wipe up the area around your treadmill at the same time. You should clean the motor area three or four times per year. Unplug the treadmill before removing the cover. Follow the instructions in your owner's manual for removing the cover. Carefully vacuum the dust and debris from around the motor.2)
Lubrication Read and follow your owner's manual for lubrication recommendations. Some treadmills do not require lubrication. In fact, unnecessary lubrication can cause damage. Many decks are made of materials that do not require lubrication or are pre-impregnated with wax. Lubricating these types of decks can actually increase the friction between the belt and deck, which can lead to motor damage. If your treadmill does require lubrication or waxing, follow the manufacturers guidelines.
Belt Tension Belt tension is pre-adjusted at the factory, however, new belts will stretch and require readjustment. If the belt is too loose, it will slip and cause excessive wear to both the belt and the deck. If the belt is too tight, it will cause wear to the rollers and to the motor. The belt should be set just tight enough so that is does not slip. With the belt running slowly, stomp your foot forcefully down and slightly forward on the belt. If you feel the belt slip, tighten both bolts 1/4 turn. Again, follow your manual for instructions specific to your make and model.
Belt Wear There are two components in your treadmill, which will require periodic replacement - the belt and the deck. Check the condition of your belt every three months. Feel the underside of the belt. If it feels rough and worn, it may be time for a new belt. Continuing to run on a worn out belt will increase the wear on the deck. The deck will eventually wear out also, but if you replace your belt when necessary, you will increase the life of your deck
I hope this will be keep your safe with your equipment.
blessing.
sincerely.
E.CUADRA
MANAGUA, NICARAGUA. C.A
Sep 13, 2011 | Life Fitness T5-0 Treadmill
While using my Nordictrack a2550 this morning, the walking belt began to slip very badly. I checked the alignment and adjusted the tension of the belt as per the user's manual but the belt stills slip...
if it really is the walking belt that is slipping keep tightening the adjustment screws till the belt will not slip when you try to stop it ( set speed to about 3 and then with your foot try to stop belt from spinning - you should be able to make the motor and whole machine come to a stop ) make sure it is really walk belt spinning and it isnt the motor belt slipping. (if it is motor belt slipping when you try to do the stop the belt trick i just described you will see the walk belt and front roller stop but still hear the motor turning) once you get walk belt tight enough so it doesnt slip then you can worry about keeping the belt centered.
let me know if you need more help on this and let me know how the stop the belt test went
good luck!
Mar 25, 2011 | Nordic Track NordicTrack A2550 PRO...
I own and drive daily a 2003 gs 300 with 152000 mi and have never changed the timing belt is this a necessity??
Check your owners manual/maintenance interval, but if I were you I would at least do an inspection. If the belt breaks or even slips a tooth, you will be stranded. The belt could possibly last another 150K, but I wouldn't want to risk trying. If you need more advice, please feel free to reply.
Sep 10, 2010 | 2003 Lexus Gs 300
When transmition warms up, it will not go up hills or pull loads
Yes, you have to remove the mower to change the belt. Is this the manual you need? You didn't give the model number.
http://lawnandgarden.manualsonline.com/manuals/mfg/sears/917255450.html
If it is not the right one the instructions for changing the belt and other maintenance are probably the same.
Aug 20, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Belt is slipping
your macnine needs some maintenance. slippage on the proform is usually due to a worn out front roller and a worn motor driving the belt. both can be replaced. or you may want to find a good used one as many get no use before the optomististic owner decides to sell.
Aug 17, 2009 | Proform CrossTrainer Treadmill
Drive belt sliping needs tightend or adjusted on rideing mower
If the belt is shiny on the sides and slipping replace it, belts need to be tensioned during regular maintenance before they slip.
May 27, 2009 | Yard Machines Garden
Do timing belts in 1994 Ford Escorts ever need replacing?
No they are not. The reason your manual does not saying anything about replacing the timing belt is because 9 times out of 10 most people do not know how to replace the timing belt and make sure that it is on properly and the timing is correct. Also the time belt should be changed around 115,000 miles. But it is never bad to go ahead and get it done if they already did it or are going to
Feb 21, 2009 | 1994 Ford Escort
Proform 495pi Treadmill Frontdrive Roller 219035 Logo
456 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
jay kaye
jay kaye
Marvin
Marvin
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
