Washing Mach... Master
- Posted on Jan 09, 2011
Re: My candy alise washer dryer stops mid programme and...
Hello &
Welcome to FixYa
The problem
is with the door lock-switch assembly not working, the unit detects that the
door is not closed/locked and so will stop in middle of cycle. Please get back
to me if you have any other questions.
Kevin
device locked due to incoorect possward
Fitting new rear crossmember to a landrover defender 90 200 tdi
registry reviver license
My daughters inno tab3s screen is cracked can I get replacement screens or any fixing services out there
how repair my samsung gt-s3653 that debug high
forgot security code of 1661-2
My right head light low beam is not working. I replaced light
reduce font size
Printing very light, but ink cartridges are at 87%
when someone sms's me the phone does not flash to warn me
How to open ports
maxxum 70 hand operated steering does not work. The motor continues to run however the steering handle moves appropriately but does not steer the boat Serial # MKAE3131628. 3X steering. It is a 74 pound thrust, 24 volt.
how do open my trunk on my 06 maliu
need to replace canister vent valve solenoid
Heater blower does not turn on. Trying to locate blower motor fuse but find it hard to read diagram. Do not have owners manual.
need a timing diagram for a 1997 mitsubishi montero 3.5 sohc v6 4wd
Looking for pic and part number for both in out lines on rack/pinion.
when printing the edge of the paper looks slightly yellow or faded
Amana gas oven will not ignite. (model#arg7301ww) the igniter will get hot but the oven burners will not ignite.
Tail lights instrument panel lights and floodlights all went out at the same time
Life Fitness 95T Inspire Treadmill
cuantos litros de aceite lleva la transmision del corolla 2005
waher does not spins during wash cycle
Suzuki an 400 backfires
At the base of the dishwasher there is a grease deposit that builds up. How do I get rid of that and then prevent it?
fan motor making noise when doors closed, shuts off when doors are open
car started fine but when put in drive reduced power light came on and i couldnt get goin. car never died just sat there. I turned the car off waited, and turned it back on engine light on but i can drive. reduced power light went off get a code of p 1290.
univerical remote controle
goes up to oneinch from top & stops. Now it won't move
=changing the clock on a 2006 honda accord
I connected my vizio flat tv to the cable box no chanels available
