Great remote but not always easy to find right category for device.
Had a look for you and sure enough the device IS listed in data base under AMPLIFIER- then select amplifier again and input vizio for make and soundbar for model and click next.Problem solved!
If you have the remote for the soundbar, you can learn the controls with the Harmony "Learn IR" button. Then add the soundbar as a device. If you still need help, post a comment and I can help you further
After much research, here is a
step-by-step for getting your Vizio Soundbar to work with the Comcast remote
using EFC codes (mine is the newer charcoal grey one, works great!)
Aux - Setup (2 blinks) - 11144
(2 blinks)
Aux - Setup (2 blinks) - 994 -
Setup - 00169 - Vol Up - Should get 2 blinks
Setup - 00168 - Vol Down - Should get 2 blinks
Setup - 00037 - Mute - Should get 2 blinks
Setup - 00165 - Power - Should get 2 blinks
Setup - 00164 - Input - Should get 2 blinks
These are optional, I didn't use
them:
Setup - 00036 - <button to use for TVOL> - Should get 2 blinks
Setup - 00101 - <button to use for TSHD> - Should get 2 blinks
Then set the volume control on
the remote and other settings according to the Remote's manual.
ENJOY!! Hope this helps someone...
