Posted on Jan 10, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Str-gx800es sony receiver problem- right channel speaker sound is 'static', low and distorted. I have checked checked all speaker and output/input source cable connections with no luck. All left channel speaker outputs work fine. Is this a problem that requires a service technician or can it be something I can do myself. I have no other problems with the Sony. Thanks for any help.
Anonymous
Level 3:
  • Sony Master 6,771 Answers
  • Posted on Jan 10, 2011
Anonymous
Sony Master
Level 3:
Answers
6771
Questions
0
Helped
1778878
Points
21413
If you have checked the speakers and wiring, the right channel has a audio driver or output problem, which explains the low volume, static, and distortion. A service technician will be required to fix the receiver so it will balance the left side.
Why is it intermittently losing channels...front speakers and or rear surround?
How to troubleshoot low sound or no audio from the rear ...
https://us.en.kb.sony.com/.../how-to-troubleshoot-low-sound-or-no-audi...
Aug 15, 2015 - Verify that the rear surround speakers are properly connected to the ...For Dolby® ProLogic surround sound, the center-channel mode must be set to ... the center or rear surround speakers for the Home Theatre (HT) system.
Why Are My Speakers Producing Static? - Electronic House ...
www.electronichouse.com/.../home-audio/why-are-my-speakers-produci...
Here are 3 reasons that speakers produce static and solutions you can try. ... If they are your dedicated front L/R channels speakers in a 5.1 or 7.1 system, you more ...Since you have no problem with your existing rear speakers, if they begin to distort on... Home Theater Subwoofer Puts Boom in This Room · Soundbase vs ...
How to Check if your Speakers are Wired Correctly ' Richard ...
www.richardfarrar.com > Podcasting
Mar 25, 2009 - Attaching speakers to your Hi-Fi system usually only requires a few cables. ..... Is this test applicable for a home theater setup with 5 speakers? ... frontstereo speakers, but to do a similar test on your rear surround speakers would ... Yes, switching polarity on one channel of the amp output to your speakers ...
Pioneer VSX-816 speaker drop out - AVS Forum ' Home Theater ...
www.avsforum.com/.../1068233-pioneer-vsx-816-speaker-drop-out.htm...
Sep 20, 2008 - 30 posts - ‎24 authors
The right front speaker sound drops out intermittently as of about 6 months ago. ...mode and back to Auto Surround would bring the center channel back. ... the push pin that holds several grey wires in place, and pull the wires loose. 9. ..... Is it possible that the cold joints are elsewhere in the system, but that ... Yamaha RX-V663: Intermittent/No Audio in Front ...
Jan 23, 2014
Sony Receiver going in to Protect Mode
Jan 12, 2012
The Official Sony STR-DH820 Thread
Aug 29, 2011
Denon AVR-1910 - No more sound.
Feb 15, 2011
More results from www.avsforum.com
Sony GX800ES protector
Make sure none of the speaker wires are touching each other. If they are, it will short out the stereo which triggers protection mode and cuts out all of the sound.
No rear speakers coming out oy my system.reciever sony STR-DG800 and bose acoustimass 10 speakers
The rear left and right channel has a audio output ic problem, first check rear speaker wires for shorts, if okay! the system will need to be assessed for repair costs.
I have an additional subwoofer 10" JBL. How do I go about hooking it up with my sony receiver GX800ES?
That is a capable unit. Do you have a user manual? If not, it is here:
http://esupport.sony.com/US/perl/model-home.pl?mdl=STRGX800ES&template_id=1&region_id=1&tab=manuals#/manualsTab
In there it says you connect the subwoofer to the "Surround Out - Mono" output terminal.
I have a Sony STR-DE605 and all of the right side channels are distorted and have to be turned up 1/4 before you can hear any ot the distortion but if i turn if off switch to the left sounds perfect.Center...
Sorry for a dump question ,
have you changed the distorted Right speakers to LEFT to verify if speaker is OK ?
First try with just STEREO ,not on Surround and please contact me for further solution possibility..
Take care..
4helpful
2answers
Right front channel not working
try to check balance adjustment if working.
My Sony STR-DE135 reciever has sever distortion on the right channel speakers (A&B) no matter which input is selected. I can not find any obvious fault on the board. Any tips to help me fix it?
It sounds like your receiver may have a damaged output IC. I'm assuming that you've already tried a known good speaker on the right channel but if not, that would be a good idea. Also check and verify that the speaker wire is not damaged and that the terminals at each end are securely fastened.
Good Luck,
BB
3helpful
2answers
I have low volume on two channels of my STR DE975 receiver
I been replied you in chat thread, please check and feel free to ask any question.
Right rear speaker has static
Sounds like damaged channel in output circuitry. Take to pro/tech
Surround sound distortion
Receivers like this will incorrectly decode rear channel audio and pass it on to the rear channels as distorted audio. Make sure the source being used really has rear channel information encoded into it. It could have other issues but check this first.
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
ZJ Limited
ZJ Limited
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
