You could try leaving it on charge a bit longer but if it keeps happening it either means dock doesn't charge the battery any longer (check for the charging symbol on the phone when in dock), or the battery in the phone has had its days.
some vtech phones put a chip in their phones and will not take an aftermarket battery...either that or its the wrong one for the phone...ive worked for a battery store for 3 years
The issue here in "most caases not all is the battery is at its prime" i would first buy a new battery let it charge for 20 hours!! then try reregistering the headset. if that does not work or reregister then you know now you got a bad transmitter radio inside. Try all reset methods as well even before you spend $12 bucks on a battery pack. Chances are its the battery, worse comes to worse the headset needs to be replaced.
thanks this was a FREE solution please do be considerate and rate and leave postive feedback thanks.
Try to reset the handset from handset menu, maybe the eeprom setting for low battery warning threshold have been ereased . Also check ,if the battery is the oregional battery for the phone.
is your phone about a year old? It may be the battery. The vtech phones have weak batteries that clunk out after about a year and you'll get dropped calls, looking for base etc... The phone still appears to be working and the battery indicator tells you it's charged, but the battery is too weak to keep the wireless connection going.
Had the same problem and replaced the battery. budgetbatteries.com had
the cheapest ones. But it's a knockoff, so I don't know how long it
will last. So far it's been 3 months and the problems are gone. I would
try that first and see how it goes. I paid about $15 including
shipping. If you buy it from vtech it's at least double...
You need to buy new batteries for your phones. Large retailers charge $10-12 per battery but you can usually find them for closer to $4 online at amazon.com or eBay.
I have two handsets, one of them recently starting dropping the connection to the base quite regularly [even if it was just inches away], and I ended-up in the same situation after unregistering the phone.
In my case, I was able to remove the battery from the phone [as you did] but also unplug the power on the base unit for several seconds. After restoring power to both, I was able to re-register the handset and it appears to be working more reliably now.
You are pretty close to the solution. The problem is the charge detection in the handset. All handsets on a cordless phone detect the battery level with an hexadecimal value in the memory. Each hex value equal a volt value of the battery. EX: 3.5v = 9B 3.6v = 9C 3.7v =9D etc... The problem is the hex value in your defective handset are all mess up. So 9B is not 3.5v anymore. Then your handset could last 1hr after foul charge or doesn't alert you before the phone goes dead due to low BAtt.
