Question about Toshiba SD-1700 DVD Player
Toshiba 4100 single dvd player won't load. Screen displays loading message but will not. Any suggestions?
  • 10,421 Answers
Please clean the lens then retry to load the disc. Replace the lens if still fail to work
Posted on Jan 10, 2011
6ya staff
SOURCE:
I purchased a toshiba portable dvd player and the disc is not spinning therefore reads no valid disc. I have put in a few discs still same reading? Any suggestions?
Hello
The Sled Motor is defective. this is the motor, whic spins the disc as it has been loaded properly. If the loader mechanism loads the disc properly into place and if the catch up magnet catches the disc in place, and still the dis do not spins, replace the sled motor. OK.
Feb 28, 2012 | Toshiba SD-P1900 Portable DVD Player
Tip
Toshiba SD-4100 DVD Manual Have you lost your Toshiba SD-4100 DVD Player Owners...
Have you lost your Toshiba SD-4100 DVD Player Owners Manual?
Would you like a digital, searchable version of the users guide?
The pdf version of the Toshiba SD-4100 DVD player is available here.
I hope that helps.
on Apr 11, 2010 | Televison & Video
Tip
I hope that helps.
on Apr 10, 2010 | Toshiba SD-4100 DVD Player
I need to find a replacement remote control. Any
The link below contains the original replacement remote for your unit.
Toshiba SD-4100 Replacement Remote Control
Dec 31, 2009 | Toshiba SD-4100 DVD Player
Dvd will not load just keeps flashing loading This includes any type of dvd. Anyone have an idea to get this thing running?
try a few different types of media....if still no luck then your going to need some laser servicing or possibly replacement. same old same old im afraid. if the unit is more than a couple of years old then be carefull how much you spend for a service. may not be worth it.
Aug 02, 2009 | Toshiba SD-4100 DVD Player
Disc error message when load DVD
Are you loading to play or to record?
Commercial DVDs should play.
DVDs for recording may not be recognized by your drive. First make sure that the disc is blank. You must insert a blank disc of the proper format: DVD-R or RW, DVD+R or RW. Even with the proper format, some brands may not behave the same way as other brands.
Dec 24, 2008 | JVC XV-N320 DVD Player
Toshiba 32'' Model 32HLV66 DVD/TV Combo - DVD won't play
you must do a optical head cleaning on the unit, could be the optical lens was dirty thats why it can't read any disc inserted.
you Lens cleaner for CD & CD-ROM player
With Voice instruction (English), Music and Automatic stop
Scientifically designed, easy to use and keeps your player's sound at optimum condition
Nov 23, 2008 | Toshiba MD13N3 13 in. TV/DVD Combo
Toshiba model sd-v383sc
Atrk means that the unit is in auto-tracking mode and trying to lock in to the tape's recorded speed. This should go away after a short period of time once the tape has started.
Dan
Jun 19, 2008 | Toshiba D-VR4 DVD Recorder/VCR
Samsung 3650 dvd/vcr player loading problem
Sorry, no suggestion other than don't buy Samsung. That's my conclusion after owning the same model. It worked fine for a while, but now won't load any DVD... usually. Sometimes it will play one, but more often it won't. Mine tries to load ("Loading") for a long time, I hear the DVD spinning, then ultimately the screen displays "This disc cannot be played" or something to that effect.
Nov 25, 2007 | Televison & Video
Toshiba SD 4800 dvd player
I've had the same symptoms on the last two Sony DVD's that I've rented. I managed to get around this by hitting one of the menu buttons after the loading message stopped.
Aug 07, 2007 | Toshiba SD-4800 DVD Player
Toshiba SD-1700 DVD Player Logo
165 people viewed this question
Top Toshiba Televison & Video Experts
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
