Polaroid i830 Digital Camera Logo
Posted on Jan 11, 2011
How do i turn on the Macro - Polaroid i830 Digital Camera
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Jan 29, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
390
Points
There is a round ring shaped control button on the right side of the rear panel. The left side of it has a little icon of a flower. Push the flower to toggle on or off the macro setting. When the macro setting is on, you will see the flower icon on the right side of the display screen.
1helpful
2answers
When I try to turn my flash on it says macro mode, What is this and how do I fix it?
Macro mode is for taking pictures of subjects very close to the camera. In this mode the flash is disabled.
Without knowing the model of your Digital Concepts camera I can't tell you how to take it out of macro mode. If there's a button on the back marked with a flower icon, press it. Otherwise look in the menu.
4helpful
Why is macro invalid in sony w dsc-220?
You mean you can't turn the macro mode on? Most likely there are some settings set that won't let you turn macro on. Do an initialization (reset) from the SETUP menu.
The distance focus ring, is it supposed to turn all the way to the macro symbol when you are focusing on a subject that is very close?
If you're right "on top" of the subject - then, yes - it should indicate "macro". Macro focusing is for "very up close" photography and is exactly as you describe. You simply physically move the camera a little closer to or further from the subject to focus.
Not all lenses are capable of macro focusing. The vast majority of these non-macro lenses are required to be at least a couple (or more) feet away to focus. Macro lenses on the other hand can usually get just inches away - which is a great capability.
Enjoy your macro lens!
ROKINON AUTO ZOOM Macro--- HELP to enable macro
Some of the Rokinon (and other ) zoom lenses could only go into MACRO at certain focal lengths- the lens you have "zooms" from 80 to 200 focal length,but is that done by "sliding" a ring forward and back on the lens, or by twisting a different ring that the one that focuses?
9helpful
3answers
I can"t turn on macro. When I push the button, I see on the display that macro is invalid.
I have a Sony W120 and had the same macro problem, tried all the "solutions" mentioned here without result. So I pressed the "Home" button, went to "Settings" (last menu item at right), then "Main Settings", and used the "Initialize" functio. Problem solved !
2answers
Use of macro digital feature
hi,let me just inform u that the macro mode is only for outdoors.So on the side of the camera u will find a sliding switch.Just slide it to the opposite direction to turn off the macro mode.Since u wanted to take pictures of jewelry pieces,turn on the flash if u have one and then take a closeup shot with good lighting conditions.If its too bright then use only the flash,if u r not satisfied with the quality then use only lights and then take a pic.Still face any prob plz get back to me.
Focus
Your camera has the ability to shoot Macro and Super Macro, although in some Dial Modes, you can't use Macro.
To engage the Macro mode, press once the button on the left side of the lens/camera that looks like a Flower. To engage the Super Macro mode, press and hold the same button for more than one second.
Macro mode range 3.9 in. - 1.6 ft
Super Macro mode range is 0 in. - 3.9 in.
To cancel Macro mode, press the Flower icon button once.
Zoom levels are limited, and you will know that when the zoom bar turns yellow. This means the zoom is not available at that zoom level.
Hope this helps.
Macro Mode
The MACRO MODE is easily accessed via the arrow pad on the back of the camera. Press the left arrow key, which has a flower icon, to start the MACRO MODE. Press the down arrow key to select the flower icon in the menu. Then press the OK/MENU button; camera is now set for close-up photography. Remember to turn off the MACRO MODE when you begin shooting subjects beyond the focus range of the MACRO MODE.
Close-up picture
The Macro Mode is easily accessed via the arrow pad on the back of the camera. The right arrow key, which has a flower icon, is depressed to start the Macro Mode. Press OK and the camera is set for close-up photography. Remember to turn off the Macro Mode when you begin shooting subjects beyond the focus range of the Macro Mode.
Top Polaroid Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Tom Shanks
Tom Shanks
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
