Samsung S860 Digital Camera Logo
Posted on Jan 12, 2011
My zoom lens is stuck. how do i fix it? - Samsung S860 Digital Camera
5 Related Answers
Anonymous
  • 51 Answers
  • Posted on May 15, 2009
SOURCE: lens stuck in out position, screen shows zoom error. How can I fix the problem?
just take out the battery ....charge it ...and put it back....switch off and switch on the camera once....should work fine
fotomohamed
mohamed salim shaikh
  • 321 Answers
  • Posted on Jun 18, 2009
SOURCE: My Casio Exilim 7.2 Megapixel camera is stuck on zoom.
ur zoom lens trrip is broken 1side dont use zoom inout strip cost 50$
Anonymous
  • 262 Answers
  • Posted on Nov 12, 2009
SOURCE: zoom lens stuck out
that error code indicates the the Lens of teh camera is already defective., In most cases if the lens is stuckout or stuckin camera will not stay On or It will not Turn On at all. For this case you need to call Tech support to send you camera for repair toll free 1 800 235 6325 extension 12
Anonymous
  • 11967 Answers
  • Posted on Dec 10, 2009
SOURCE: lens is stuck in full zoom position Olympus 7010 camera
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
t00nz
CameraR
  • 4738 Answers
  • Posted on Feb 21, 2012
SOURCE: Dropped camera zoom lens is stuck
Here are some troubleshooting steps that you can try that may (or may not) correct your problem. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them. And am guessing that your lens may be crooked from the fall, so you may need to progress to Fix 7b first to straighten it before proceeding with the others. Good luck!
Nikon lens 35-70 af zoom ring stuck
This is not a do-it-yourself type of repair. If you try to do any disassembly of the lens yourself, you will end up with a table full of parts you will not be able to properly reassemble and it will cost twice as much to have it fixed. Send the lens to Nikon or a professional camera repair man.
2helpful
I have a Nikon D40, which I recently dropped. :( Camera seemed okay, but then I noticed later that the 18-55 lens was being less than cooperative. It now is stuck on 55 adn will not zoom out. It still...
It sound like the lens zoom has broken.
If other lens is ok and this lens still focuses automatically the conection is working.
Sorry to bring the bad news but it may cost less to get a new lens than to get it fixed.
Someone else might have an idea how to fix the zoom, good luck.
4helpful
2answers
Canon EF-S 17-85mm - Stuck Zoom
this lens has a design shortcoming in it's aperture's ribbon cable ,the cable will rupture after around 1 year using, this problem taken place in more than 60% of owners with this lens. Canon has no respons with it problem and ask you send to their quick fix store for repair.
Lens is stuck
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
1helpful
2helpful
2answers
Lens stuck in out position, screen shows zoom error. How can I fix the problem?
9helpful
Zoom lens is stuck on my camera
Hey, my husband just fixed it! You just wiggle/bend the zoom lens, and you feel a "pop", and then the zoom retracts and you're fine! I was afraid to "break" it, but someone on vacation had the same problem and told him this solution a few weeks ago. So don't be afraid to use a little force-at least, in our case, it worked! Good luck.
1helpful
Lens stuck
It sound like a problem with the zooming mechanism (lens would not retract or extended) Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. In any case it could not make it worse Good luck!
3answers
Top Samsung Cameras Experts
ZJ Limited
ZJ Limited
Are you a Samsung Camera Expert? Answer questions, earn points and help others
