Ul code whirlpool cabrio the whole time at the end of cycle
The water level cannot be adjusted, but sometimes the pressure hose gets obstructed. Remove the three screws from rear of top panel to gain access to the main control. The pressure hose is attached on the RH side of it. Remove hose and blow through it to assure clear air path. If problem remains, replace control. Control available HERE, and using coupon code 1050 will get you a discount on the part!
