First thing I would do is check the SWR on the antenna. These newer radios have a strapping diode that shuts them down when the reflected power heats the finals up to keep from blowing them. Once they cool off they will work again.
SOURCE: cobra 148 gtl vr12
if you want more than that you can clip the limiter insde the radio that will be r 131 by the first can with the face of the radio toward you on the right. in front of the can. there is a transistor in front of the can then the resistor.
SOURCE: No modulation in AAM only mode. Needing a schematic.
if the transmitter produces power output with modulation on SSB but NOT ON AM then the AM Pass Regulator is defective, more times than not.
SOURCE: need a new Cobra 150 GTL DX power,vol,sqlch pot
you can write to parts department requesting price if you have a truck stop around you which has a cb shop they can sell u one
SOURCE: Cobra 150 GTL DX Base CB Radio
they have a surface mount audio driver transistor. if replace with a to-220 version normally the warbling will go away. same for the 200gtl
