Tippmann A 5 Standard Paintball Gun Logo
Posted on Jan 12, 2011
I got a co2 leak - Tippmann A 5 Standard Paintball Gun
Andres Santana
Level 1:
New Friend:
  • Contributor 23 Answers
  • Posted on Mar 18, 2011
Andres  Santana
Contributor
Level 1:
New Friend:
Answers
23
Questions
0
Helped
6647
Points
44
The A5 standard is a pretty compact gun depending on the place of the leak I could assist you better. In any case you best chance is to check for leaks in the o-rings at the CO2 bottle, at the regulator.
Hi, I am trying to remove a brand new CO2 cartridge I just put in a new Gamo PT-85 Blowback pellet hand gun. As I'm unscrewing it, gas is leaking out. HELP.
Hello K Brink,
There is no going back... Once the CO2 cartridge is
pierced... there is no way to salvage the cylinder
until it is FULLY expended...
If you unscrew the chamber the CO2 will ALL be released.
Just ONE word... If your cylinders are depleted... ALWAYS
check that the SEALING O-ring stays with the hand-gun.
Just make sure yur SEALING RING is still in the "gun"
and NOT STUCK to the ... co2 CARTRIDGE.
I am just saying...
((been there... Done that))...
Carnac the Magnificent
Nov 29, 2017 • Gamo Optics
My Crosman 1008 Repeat Air pistol leaks all CO2 out
The crosman 1008 does indeed fire pellets! NOT BBs. ONLY pellets.
Co2 install
Your seal is probably out...
2helpful
Air leaks out when installing co2
The Phantom Break-Barrel does not use CO2. It is a spring-loaded break-barrel weapon. If you really do have a CO2 gun, check the rubber seal around the outside of the cartridge puncture needle.
I was playing today and my 98 custom just started leaking CO2 from all the cracks it froze up and ice started coming out of the barrel. what happened and how can i fix it??
your tank loosened up, the co2 freezes the rubber seals they will have to be replaced, you can order a repair kit from the website, change out all the rubber seals on the gun and your co2 tank
Daisy Powerline 1700 leaks CO2 very slowly but
Replace the seals.
Recommend an eBay or Google search or contact Daisy directly here:
https://www.daisy.com/contactus
Oct 17, 2009 • Daisy Toys
3helpful
After inserting and compressing the CO2 cartridge, the CO2 leaks
You need to check the rubber o-ring seals both in the plug and there could be another up in the gun where the cartridge end meets the inside. If you have a broken o-ring you should be able to find one that fits at your local hardware store or store that sells air rifles. Hope this helps.
1helpful
Co2 leak
Did you check the O-rings?
Danby DKC645BLS Kegerator
i had the same problem with mine. i fixed it by removing the guts from the faucet and reversing the seal on the closing part. the seal was on backwards, flipped it and no more leak.
Top Tippmann Sport & Outdoor - Others Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Tippmann Sport and Outdoor - Other Expert? Answer questions, earn points and help others
