It is not clear what problem you are experiencing with an ".exe" file. ".exe" files are executable files that contain instructions that can be run on a computer. Some common problems that you may encounter with ".exe" files include:
If you are experiencing a problem with a ".exe" file, you can try the following steps to troubleshoot the issue:
This error is generally an indication that the written program isn't designed to be run in the 32 bit windows environment, the program is corrupted, or an error occured while trying to run the program. It is generally due to an older program being run within windows.
The newer windows versions are mostly 32 bit platforms. Some of the old programs from windows 95 and 98 eras won't work because they are 16 bit programs. Examples may include older programs with a .com extension (which will bring up this error message), or old versions of .exe's written for 16 bit environments.
If the program you are attempting to run is a recent program (came with your version of windows XP or later) then it could be an error at execution or the program is corrupted. If the program is written by a major brand and is relatively new, contact the program's technical support number for help.
If you suspect a program error, try and obtain another copy of the program. Uninstall the current copy of the program, restart your computer, then install a fresh copy. If the error continues after doing this, then contact the program manufacturer's technical support number.
If the program you are using is one of the programs from within windows, (from the system 32 folder for example, and include notepad.exe, msconfig.exe, or other programs that can be selected and run from within this folder) do NOT remove or copy over the program. Some of the programs within the windows sub-directories are older 16bit programs, not designed to run within the 32bit platform. It is recommended to NOT remove any of these programs from the windows sub directories.
