Samsung BD-P1500 Blu-Ray Player Logo
Posted on Jan 12, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Blue ray will not play dvd but will play blue ray samsung db p1500
William Dehn
Level 3:
  • Master 318 Answers
  • Posted on Jan 12, 2011
William Dehn
Master
Level 3:
Answers
318
Questions
0
Helped
112778
Points
1021
Blue ray uses a blue laser spectrum and DVD uses the red spectrum. The blueray player must have dual capability to play both red and blue spectrum discs. If it has been and is broken, contact the manufacturer for the 1 year warranty. If it has never played DVD then most likely its not compatible.
Dvd salt wont play on my samsung blue ray dvd player
go to internet and get the new driver for your blue ray playes follow the instructions and down load it to your player i used a flash drive to load the driver up date . that fixed that problem some still takes a minit or so to load the movie but to is alot faster than before i could not get some movies to load till i updated my driver hope that fixes your problem good luck
Unable to play new SALT film blue-ray on my BD-P1500 and can not seem to fix it
The player needs a firmware update. Your issue is a direct result of this. Go to the Samsung website to access the appropriate download or simply connect your player to your modem with an ethernet cable (TV needs to remain connected to player for menu navigation) and update firmware.
This will solve your problem!
Hope I helped!
1helpful
2answers
Samsung BD-P1500 Blu-Ray Player won't play salt blue ray dvd
Connect the ethernet cable to the backside of the samsung bluray 1500 player ethernet connection with the bluray player power on with no disk & it will automatically update your bluray. It should be work fine after update your bluray. Good Luck!
1helpful
My samsung blue ray will not play a blu ray disc at all ,it will play a normal dvd ,wtf !!!!!!
This is all to common problem and indicates a Laser Pickup Assembly issue. The blue ray require more precision and velocity to produce the higher resolution that is demanded to play them, either way the assembly must be replaced or a new machine bought.
Get message This disk can not be played. Please check the tv system from bdp1500 blue ray player. Disk plays well on another dvd player. What's wrong
Happening to me as well.. I have burned dvd-r that I made myself.. and it will not play.. I have all kinds of different dvd-r's and none of them worked.. ran the latest firmware.. nothing!
1helpful
1helpful
Blue ray quit recognizing non BR disc
The non-blu-ray laser lens needs cleaning.
Try not to use a blast of compressed air.
Radio Shack has a lens cleaner ($13). it is an audio CD with a row of brushes on it.
Read & follow the directions.
Samsung BD-P1500 Plays Blu Ray but not DVD's
Nope. The laser mechanism seems to have developed a preference of its won and refuses to work with DVD media.
You have already done a firmware update so that is ng. Could be that when you updated it to play newer blue rays, the update messed up unit for dvd playback. Happens.
But do not sweat - that unit has a one year warranty - use it.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
