I have a crime stoppers remote start/alarm when I use the unlock button it only unlocks the doors, it does not disarm the alarm. How do I disarm the alarm?
If the remote is arming and disarming the alarm then, it should be locking and unlocking the doors as well. The door lock and unlock wires need to be connected. Are sure that they are connected? Do the door locks work with the switch?
Is this an aftermarket alarm? If so, first locate the valet switch. It should be a black push button. Next, turn the ignition on, press and release the valet switch. This should disarm you aftermarket alarm. This is the most common manual disarm procedure for Directed (avital, python, Automate, Viper) and Audiovox (prestige, pursuit, code).
If this is the factory alarm and, you don't have the remote. Unlock the vehicle using your key in the driver's door.
That is a function of the security system. Are you sure you want remote start without locking the doors? I don't believe you can change the programming of that function but the user manual for your alarm should explain how if it can by done.
30 seconds or minutes. If seconds then the installer taped into the dome light circuit for the door trigger and when the light turns off it's setting off the alarm.
try this web site by crime stopper www.crimestopper.com or you can call their tech support at
800.98.6880 ext 210 you may have to program the remote again. you can also find that at the site by choosing support manuals then manuals again and finding the model number of the actual unit not the remote
a connection may be faulty on your siren or car horn you can find the manuals at www.crimestopper.com under support then choose manuals and manuals again you have to use the model number from under your dash not the remote because they may be different if that does not work you can contact their tech support at
800.998.6880 ext 210
I am almost positve that your 2000 intrepid has one wire door locks, meaning there is one wire that goes to the factory lock module and is hit with different resistance values for lock and unlock. this is tricky. you have to find out what the two different resistance values are, and use two resistors inbetween the alarms lock wires, and the wire you hook to in the car. Stop by your nearest best buy, the guys in the install bay will probaly look up the info for you. I know I would at my shop.
