Question about GE Washing Machines
I have a GE washer model # WJSR4160G2WW it will fill with water and spin but will not agitate. We can hear sounds like it agitating but it is not. I purchased the machine in March 2009.
  • GE Master
  • 8,220 Answers
Posted on Jan 13, 2011
Anonymous
SOURCE:
I have a GE spave maker Laundry that fills up with water than stops!
GE Washer Not Agitating Repair Guide
www.appliance-repair-it.com/GE-washer.html
If your washer will not agitate or spin take a look at this page GE Washer Not ... If the washer fills up with water then doesn't do anything at all and you do not hear ... if this were the problem, the water would not stop running, over-filling the tub.
GE washer spin cycle not working - ApplianceBlog
www.applianceblog.com/.../217-GE-washer-spin-cycle-not-working
Mar 12, 2005 - 10 posts - ‎3 authors
I have a GE "Spacemaker Laundry" (Stackable) model number ... Today it filled withwater initially then stopped working all together when it ... Bad motor, something jammed/seized up holding the motor back from running?
Jan 10, 2016 | GE Spacemaker Washer and Dryer Electric...
Will not spin or agitate
did the washer cause the flood? you could have got water into the motor if it was above a few inches deep. do you hear the motor working, and no agitator movement? will it fill ? or is it just dead?
Nov 10, 2013 | GE Profile WPRE6100G Top Load Washer
GE Washer WJSR2080V3WW will fill, spin and drain but not agitate.
The problem is the agitator coupler (about $ 7.00) simply pull straight up on the agitator - Give it a good tug. take the one bolt holding the coupler off - pull straight off. Replace the coupler and bolt (they are sold together). Line the agitator lines up with the coupler lines - when they line up it should go all the way down and snap back into place. and your done.
Sep 01, 2009 | GE WJSR2080V
Does not agitate or spin
Let me make sure I hear your symtoms right..
The washer fills...sound like the motor is running but it doesn't agitate or spin.. then when it tries to drain it bascially gravity feeds out until there is no longer enough water to force it out?
Sounds like the belt is off, or broken.. I am not all that familiar with your model, but I think most GE's are belt drive.
If it were the agitator coupler, the washer would probably still drain..
Pull the front cover off of the washer, you will see the belt and pulleys, make sure it is A: still on the pulleys, and B: tight.
If not, loosen the four bolts on the moter, put the belt on and then slide the motor towards the rear to tighten it.. then tighten the four bolts. They may simply have not tightened the bolts on the motor from factory and the motor slid back loosening the drive belt.
GOOD LUCK!!!
Jun 20, 2009 | GE Washing Machines
Washer will not agitate or spin
HI,
you can view this site to have some ideas about your agitator problem.
http://sites.google.com/site/sublimeappliancerepair/washer-will-not-spin/agitator-woes
any further question let me know.
thanks,
Mar 29, 2009 | GE Profile WPRE6100G Top Load Washer
GE top loader not agitating
Your agitator splines are probably stripped out.
Remove the agitator and check the spline grooves.And the agitator coupling on the shaft.
Mar 04, 2009 | GE WBSR3140DW Top Load Washer
Old model rca washer machine...will not agitate/wash the clothes,does spin.
If the washer fills up with water and you hear the motor running but the agitator doesn’t move, the agitator coupling is the most likely problem. First pump the water out by turning the timer to spin. Once the water is out, turn the washer off. Now pull up on the agitator until it comes off (it may be hard to pull off). Now that the agitator is off, you can see the agitator coupling, reach down and try to turn the coupling. If the coupling turns freely, it is striped out and needs to be replaced.
Sep 29, 2008 | Washing Machines
Washing Machines Logo
613 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
Gerry Harvey
Gerry Harvey
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
