Question about Hitachi 42PMA400 42 in. Plasma Television
Same problem as mark_free256 posted on 22/12/10. "We have a Hitachi 42PMA300A and the screen is full of coloured vertical lines. Sound is ok but no picture other than the coloured lines." Same screen result for other media eg. dvd or set top box. Seems like screen is rolling extremely fast. This happened at 1st. use this morning but I have noticed extensive pixilation occurred on all channels previous week. What is the problem?
  • les5272 Jan 14, 2011
    Thanks for the straight-shooting advice. It confirms what I had suspected. Went straight out and bought a 46inch SONY BRAVIA KDL46EX500 (LCD HD 100Mhz) for AUD $1165
  • les5272 Jan 15, 2011
    Many thanks, already drawn up adv. for sale.
  • 10,515 Answers
There are two things that can cause this, a buffer board and the plasma panel itself, the bad news is that there is no way to determine what one is causing it without putting the buffer board in the set. If the buffer board fixes the problem then case closed, if it does not fix the problem then the plasma panel itself is bad and the tv will be non repairable because the part will cost over $1300! Yes that is not a typo it is really over $1300.
Now if you have a professional install this for you, you can expect a bill of around $200-$400. Now that repairman is taking a risk because there is no way to know if it is going to fix it because the manufacture made no way to troubleshoot it, therefore he might pass the risk off to you and say something like:
If you want the board replaced and it fixes it then it is going to be $200-$400 (whatever he charges) BUT if I put the board in there and it does not fix then problem then there will be a $150 fee for trying, this is to cover my time and the expense of sending the part back and the restocking fees I will incur.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Jan 13, 2011
  • taran_2005
    taran_2005 Jan 14, 2011
    Thanks for your response!!
    I am sure you would have a wonderful time with Sony TV. Regarding the old TV, i have a suggestion, that you should put a bid on ebay or sell on craiglist rather the dumping the TV. There are many people who actually buy TV for parts, so there is a good way for you to still earn few hundred dollars by putting the TV for sale.
    Thanks and Regards
    taran_2005
6ya staff
SOURCE:
Sony kdl 42-w706b dark multi colour vertical lines on screen bright screen sound ok would this be t-con board or led driver?? thank you any help would be appreasted
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Jan 29, 2017 | Sony Televison & Video
Sound only w/1 straight red line accross the middle of the screen
try to replace the vertical ic and resolder the vertical section.
Sep 16, 2009 | Hitachi 36UX01S 36" TV
LCD monitor have Vertical lines and black colour become greenish
normally the 19" resolution can support up to 1280*1024, but if it comes with vertical lines in full screen, it might indicate the panel is no longer to work and probably it's time to replace new one.
Aug 12, 2009 | Neovo S 19 19 in. Flat Panel LCD Monitor
Black colour displaying become greenish and narrow vertical lines
Most LCD monitors have a default refresh rate of 60 Hz. Older monitors also have limited resolution. Please check your display settings and ensure you're not using a refresh rate higher than 60, or a resolution higher than what it supports. If either one is the case, you're lucky the LCD still works.
Aug 12, 2009 | Computers & Internet
Vertical white lines on screen
Sep 10, 2017 | Hitachi 42PD6600 42 in. HD-Ready Plasma...
ESA EDTV - 42 inch plasma TV, sound OK no picture.. has vertical lines.
pull plug. allow to reset. try again.
good luck on that, otherwise you need service.
good luck
mark
Nov 28, 2007 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Lines on tv
Set starts, horizontal and vertical deflection work, HT ok, crt heaters ok, but no sound or picture
I turned the G2 voltage up and noticed a white screen with flyback lines, frame ok. I detected two badly soldered double diode rectifiers in the secondary part of the power supply ! I checked all other joints, and everything was ok !! success
White horizontal line (no vertical deflection)
Check / replace R548, R549
Sound but no picture except for a couple of horizontal colour lines
Replaced the frame chip TDA8356, set now ok
Nov 23, 2007 | Mitsubishi WS-65511 65" Rear Projection...
Hitachi 42PMA400 42 in. Plasma Television Logo
122 people viewed this question
Top Hitachi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
