Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Hello, The over temperature reset button keeps going off. Everything seems to be working fine with the fridge, I don't know why it keeps going off. Sometime it won't go off for weeks and then all of a sudden it starts up again. do you have any suggestions to what might be going on? thanks
3 Suggested Answers
6ya staff
SOURCE:
Anonymous
SOURCE: over temperature reset button keeps ringing and blinking
I called the KitchenAid customer support number. Found out that control goes off when the temperature of the fridge is above 48 degrees (i.e., over a few days, the food would be spoiling). This is not the case for ours, since everything seems to be working fine. They said there is probably something malfunctioning with that button/control, and there is no manual turn-off mechanism. We have to call someone to come and fix it.
Posted on Jan 30, 2009
Azrael SRL
  • 11800 Answers
SOURCE: Whirlpool Gold GC5NHAXSB03 french door
Yes, the thermostat for the fridge section has failed and it will have to be replaced.
Here it is
http://www.appliancepartspros.com/part_details.aspx?part_id=4299920
And here is the diagram with its location
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5138979&diagram_id=28124840#d28124840
Posted on Jun 01, 2011
What temperature should i have my top half fridge of my hotpoint fridge/ freezer as it is too cold and everything is freezing
A good setting is in the middle of the thermostat range. For example, if you have numbers from 1 to 9, 5 would be a good number. If this setting continues to freeze, look for a bad thermostat or temperature thermistor.
Oct 01, 2014 | Refrigerators
F&P E521T beeping
If it is beeping, it has a problem other than the beep that needs to be addressed. This is probably outside the skill set of the average person.
May 05, 2014 | Fisher and Paykel Refrigerators
Aeg santo fridge keeps freezing
Fixya will not let me post links today, or their "capcha" thing does not seem to be working properly, so I will have to try this another way.
I've done some research on your issue and it seems that should only happen if the temperature sensor goes bad, or the evaporator sensor. Each of the two parts cost less than 30 pounds each, so may be less expensive than tossing out the whole thing.
Try browsing to shop (dot) aeg (dot) co (dot) uk
Then in the search at the top right, type in "santo" and look for the two sensors and decide if it would be worth a try.
Oct 14, 2013 | Refrigerators
Frigidaire refrigerator flashing
Check if the bulb holder is not loose.
Jul 29, 2013 | Refrigerators
Icemaker does not make much ice
Could possibly be a temperature sensor, but most likely the heating coil that heats the ice receptacles is burned out. The ice maker needs this heater to momentarily heat the walls of the ice receptacles so that the ice will easily come out of them.
Sorry, but this usually means a new ice maker. They're pretty easy to install and really don't cost that much (less than $150).
Jun 10, 2009 | Samsung RS2578BB Side by Side Refrigerator
Control panel on my fridge
Pull the power cord for 5 minute to reset the control board. if this control panel malfunction still exist after the reset, replace the control circuit board.
This is a typical control fault that should be corrected by pulling power for 5 minutes. if not, this reset will confirm major damaged to the circuit board.
May 25, 2009 | Maytag MFI2568AES Stainless Steel Bottom...
Over temperature reset button keeps ringing and blinking
Jan 29, 2009 | KitchenAid Superba Architect KSCS25INSS...
Refrigerator Keeps Running
A fridge normally runns for 16 hours a day, it sounds like it does exactly that. It is doing everything it serpose to. Is there anything else that it is doing? If you can give me any information I will try to help. But it sounds fine so far
Please let me know
Jan 11, 2009 | Refrigerators
Freezer okay, fridge warm
i suspect a faulty defrost heater/thermostat or defrost timer. any other questions you can e-mail me @ hvac.tech7872pr@gmail.com
Jun 15, 2008 | Refrigerators
Samsung french door fridge not working?
I had the same problem ("OF" on display and not working) and just found a fix and it worked (on SAMSUNG site).It was correctly stated that fridge is in "demo" mode. You need to push and hold POWER FREEZE and ENERGY SAVER buttons (not "Fridge button and the Power Cool buttons" as it was suggested above).
Oct 14, 2007 | Samsung RM255LASH Side by Side...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
1,325 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
geob91
Dakshinamurthy...
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
