Hi
The Panasonic Lumix DMC-LS80 feature to add the date/time is called TEXT STAMP. From the Playback menu select TEXT STAMP > MULTI then press MENU/SET
Make sure you have the time and date set on the camera already!
Keep in mind the image quality may be slightly worse if you use this function.
Hope this helps.
David
Press [MENU/SET]. Press up/down to select [CLOCK SET]. Press up and down to set time. Under Appearence set date, time and the display order for the date and time. Press [MENU/SET] to close the menu.
You can read more about this in the user manual, page 19: http://panasonic.com.au/content/library/files/F002107.pdf
