1. Empty the drum via the filter / trap at the front (there is sometimes a drain pipe near the filter - otherwise be prepared to use lots of towels to soak up the water).
2. Check / clean the filter.
3. Ensure that the drainage pipe is not blocked.
4. Check that the pipe from the pump to the waste water pipe is not kinked / blocked.
5. Check that the pipe from the drum to the pump is not blocked.
6. Does the pump sound like it's trying to work? If not, it could be that the pump is dead. Pumps can often become blocked with fluff / slime from the machine.
drum not moving
