Make sure your speakers are wired to the amp with correct ohm load, turn gain, bass boost all the way down on amp, zero out your equilizer on the cd player and turn it all the way down then start raising volume on cd player., when u can start hearing music thru the subwoofers adjust the cd player volume till the sound from your subs is at its peak without any distortion. then start raising the gain on your amp till you are happy with the sound. It gives you the optimal signal strength coming from the cd player and the smoothest sound.
