NEC (50019497) Projector Lamp for VT440, VT54 Logo
Posted on Jul 13, 2008
No image I am currently connected via the S-Video, but I can not get an image to show. Can you please help me figure out what I am doing incorrect? Thanks
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Aug 01, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1477
Points
Try switching your input source and make sure you select S Video. Also you can try to feed a composite (RCA - Yellow Cable) into it and see if you get an image. Are you able to get an image/blank screen? Can you access the menu and see it?
Sansui no signal
Acer produces a number of LCD computer monitors. Acer's monitors range from 17 inches to 27 inches. Some monitors offer wide-screen viewing, embedded speakers, high-definition visuals, and various display connection ports. Acer computer monitor problems include common issues such as dead pixels, error messages, and blank screens caused by incorrect connections. Some reviewers have also detected image problems with DVD playback on some models.
"Input Not Supported" Error Message Acer computer monitors such as the G24 may issue an "Input Not Supported" error message when users set the display resolution too high. The G24's maximum display resolution is 1920x1200 with a 60Hz refresh rate. Maximum resolutions vary according to the specific monitor model and according to the capabilities of the computer's video card. b> "Input Out of Range" b> Some Acer computer monitors may report an "Input Out of Range" error message due to incorrectly set monitor refresh rates. Much like the display resolution, each monitor also has specific monitor refresh rates with which it is compatible. Blank Screen or "No Signal" Error b> Like other monitors, Acer computer monitors feature color-coded power indicator lights. If the power indicator light shows green, the contrast or brightness levels may be set too low and should be adjusted via the OnScreen Display. If this does not rid the monitor of a black screen, the monitor may be experiencing hardware failure. The "No Signal" or "Check Cable message" may indicate a problem with the monitor's cable connection with the video card. This error may also appear on a blank screen backdrop if the monitor is plugged into the incorrect port on the computer or if the computer is frozen and needs to be rebooted. Faulty power cords or outlets may cause the screen to be black and to show no power indicator color. b> Image Issues b> Some review sites such as CNET have reported problems with streaking and ghosting during DVD playback on some Acer computer monitors such as the AL1931. (A "ghost" is an identical offset image as the primary or desired image.) Unstable or unclear image issues may be caused by incorrectly programmed VGA timings or incorrectly installed monitor drivers. b> Dead Pixels b> Dead pixels and sub-pixels can cause a variety of display enjoyment problems. Acer will only accept returns on LCD computer monitors that have "more than four (4) defective pixels per million pixels." Further, the central area of the monitor may have no more than one defective pixel. Acer does not differentiate in warranty terms between pixels and sub-pixels. Hope this helps.
Magnavox dvd recorder/vcr
It sounds like you may have your vcr connected via composite cable. Check the back of your VCR and follow the cable to your TV. You should see a Red, White and Yellow connection on both ends. The Yellow connector is the video.
Here is an image to help you find it:
1helpful
2answers
Won't log into pandora
http://us.marantz.com/DocumentMaster/us/PressReleases/PandoraProblem-M.pdf
2helpful
2answers
Messed up Bootmgr on a Nokia IP350
Have you tried the steops below
1. Get the IPSO image you want to install.
2. Copy it to an internal host capable of FTP.
3. Connect to the console on the IP130 and start it up, when you
get past the bootmanager part where it shows the prompt
BOOTMGR[1]>install then ftp or help a few other commands
4. The interactive prompts should help you figure out what to do (like assign it an IP and ftp to the server).
5. Let it install the image and reboot.
9helpful
2answers
Ps3 plays audio but does not show image on tv
Well you can just use the hdmi cable if you're going both audio and video in to your tv. With your hdmi cable you get the best quality for both.
But in anycase, it seems that your PS3 is set up to output video via HDMI cable. To reset our video output settings, simply power down your PS3 (turned off) and hold down the power button until you hear the second beep. (around 5-10 secs) Power back up and hopefully you'll have video via your av cable. Hope this helps.
Cannot show laptop image on external monitor via Svideo connector
If you want to use your TV as an external monitor, you have to connect them via VGA (top) or DVI (bottom) cable.
Which connections does your Philips monitor have?
Sending data /images / mp3 via bluetooth to other mobiles
it will not show u sending via bluetooth but it sends as beaming the file
Transfer video from cam to pc via 1349 cable
my computer recognises handycam when i connect via usb. but iam not able to connect via ieee1374 cable.in im ycom,devicemanager, there is no imaging device when i connect via iee1374 cable.do i need some drivers or in need to make some changes in cam settings.my comp is
amd athlon 64 bit, 700mb ram, dvd ram drive,my 1374 port is with via chipset.
2answers
Video output showing black and white display
Make sure the DVD is not on the PAL system. Trying to watch a PAL dvd on a NTSC TV or DVD player will play it back in black and white only.
Top NEC Office Equipment & Supplies Experts
Alexander
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
