AA is displayed when there is a sudden ambient temp change. Leave the mc-510 out of its case in the room where you are going to use it for 5 minutes and try again.
here is a link to the instruction manual
www.omron-healthcare.com/export/.../IM-MC-510-E2_02-08-08-EN.pdf
1 Consider that most digital thermometers take a temperature in less than 30 seconds, quickening the temperature-taking process for squirmychildren.
2 Read the thermometer's instructions carefully. Never throw the instructions away. Keep them near your digital thermometer.
3 Wipe the thermometer probe with a soapy washcloth or a tissue dabbed in isopropyl alcohol or put on a clean probe, depending on your brand of thermometer.
4 Turn the thermometer on.
5 Use a gentle rocking motion as you insert the thermometer into the ear canal or rectum. Never push or cram the probe into the body. Forcing it causes pain, especially if there is swelling in the ear canal or rectum.
6 Listen for the beep.
7 Remove the thermometer.
8 Read the thermometer. If you see "ERR," you did not get good contact with the ear canal or rectum, and will need to take the temperature again.
9 Use the chart insert that comes with your thermometer to see what your normal reading should be.
10 Clean your thermometer probe with a soapy washcloth and/or isopropyl alcohol before storing.
When machine is off, press and hold "ON-MEASURE" button until you hear a beep. Release button. You will see "F" flashing. Press button again to change it to "C"
