Question about Whirlpool Duet GHW9150P Front Load Washer
MACHINE NOT SPINNING OR DRAINING - Whirlpool Duet GHW9150P Front Load Washer
    New Friend:
  • 33 Answers
You most likely have a clogged or faulty drain pump. To access this: 1. Remove the bottom access panel. 2. Remove the front of the pump filter. Keep in mind that when you do this all the water in the machine is going to come out. 3. If the filter of the pump isn't clogged then you likely need to replace the pump assembly.
Posted on Jan 14, 2011
6ya staff
SOURCE:
Beko washing machine not draining water
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 13, 2011 | Washing Machines
Washing machine is washing but not draining or spinning
heatman101
Apr 26, 2011 | Indesit W 123 Front Load Washer
I have a LG WM0642HW it stopped draining, and sounds like pump is spinning but no water. I opened the filter plug and no obstuction and tried draining with small hose no water. but there is still water in...
heatman101
Apr 17, 2011 | LG WM0642H Front Load
Not draining n spinning. incomplete washing cycle.
heatman101
Mar 16, 2011 | Washing Machines
Not rinsing or draining or spinning
heatman101
Oct 10, 2010 | Hoover HC6 110M Front Load Washer
The machine is not spinning or draining
heatman101
Oct 10, 2010 | General Electric WCSR4170D Top Load Washer
Not spinning or draining
heatman101
Sep 18, 2010 | Bosch Washing Machines
My Whirlpool Calypso Top Load Washer isn't draining or spinning. What can I do?
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Sep 07, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Not draining or spinning
heatman101
Sep 03, 2010 | Whirlpool Washing Machines
Washer isnt spinning out does drain but not spinning at all
heatman101
Aug 29, 2010 | Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
32 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
